Lithium grease
Clean with carb spray and lube carb springs with the lithium grease-
the white spray stuff correct?
Other parts:
silcone spray on a rag- wipe all the rubber weather door seals and the one on the sunroof too
silcone spray onto all rubber boots on CV axles- inspect for tears in boots!!
silicone spray all the rubber bushings you can see- sway bar- suspension -steering points- keep the rubber soft is good
Other parts:
SidhuSaaB
05-30-2020 12:40 AM
guitarplayer16
11-29-2015 02:03 PM
