lights
lights
hello,
when doing mods to the lights on a car you all talk about clearing them out and making them white or whatever color, how do i go about doing this, do i need to buy new lights or just the plastic parts that cover the lights. and what are HID lights, im new with car lingo and mods. anything is appreciated.
chrisTL
chrisTL
clearing headlights usually means removing the orange strip. the easiest method involves replacing the stock unit with an aftermarket unit that does not contain the strip. however, if none are available, then this requires you to split apart the stock housing to remove the strip, and then resealing it with silicone. the ghetto way is putting a colored vinyl sticker over the lens, but you can make this look good if the strip is no where near the middle of the lens.
HID stands for "high intensity discharge". the brightness of the lights involves igniting a gas inside a bulb instead of lighting a filament in normal halogen bulbs (if i am not mistaken).
thank you, second part of my question, where can i find these lights that are pre-done without the orange strip? what do most of you guys use an particular brand you find that looks the best? again thanks!
i think i have seen aftermarket clears for the cl's, but there is probably nothing for the 2002 tl's because it is so new. i do think there are aftermarket clears (from seeing user pic posts) for the pre-2001s but i am not really sure. you can wait if you have a 2002 (don't know how long though), or try making clear headlamps yoruself using the stock unit.
yea i have a 2000 TL so i dont know which i will go with. i have a feeling that if i try it myself i am going to make it look like complete shit. any other things i can possibly do? can you do anyhting to HID lights or are they awesome as it is?
I wouldn't touch your HIDs.... People are steeling them in NYC because everyone wants our HIDs....
2001 Acura 3.2TL Non-Navi
Satin Silver
FormulaOne Premier 35
(Metalized 35% Tint)
Satin Silver
mada51589
05-03-2022 08:54 PM
sockr1
10-01-2015 01:31 AM
wusty23jd
09-24-2015 11:41 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
