Light behind the defrost switches!
Well i recently had my 2 lights on the defrost buttons go out on me, so if i have my lights on at night i can't see the defrost buttons, i would like to fix this.
I recently did the ipod hook up with the ice-link so i can use my steering wheel controls, and after putting everything back together all the lights behind the buttons on my ac block went out, except the tempeture reader.
I have a 2000 tl with navi.
My question is , how easy is it to replace those lights and can i do this myself, or do i have to order a whole new button, with the light in it all ready?
than for any help
than for any help
I remember someone post this b4. but is easy the AC controll switch light bulb can replace and they use the same size light bulb as the clock bulb.
read the following post might help you.
https://acurazine.com/forums/showthread.php?t=124416
Check out this thread
https://acurazine.com/forums/ramblings-12/look-who-else-they-found-124791/
You save a lot of money by go to radioshack route. I just changed 4 lights in my AC control unit (navi) cost only $3.19. It took me 2 hours though because I have to removed the middle console & HU. However, if you don't have navi. It should take less than 30 mintues.
ChairmanMaoSaysRTFM
https://acurazine.com/forums/showthread.php?t=124791
for you it looks pretty easy to change the bulb in your navi climate control. the HU is not hard to remove, but i'm assuming you allready know how to do this so i will skip ahead. just remove the faceplate of the climate control by using a screwdriver to depress the locking plastic tabs where it meets the control housing (see picture). the bulb twists out with a small flathead screwdriver. replace in the opposite order and you're done.
the head unit should come out in about 10 minutes. there are really only 6 or 7 screws to remove to get everything out. let us know how it goes!
SSTS
mada51589
05-03-2022 08:54 PM
HeloDown
09-08-2015 06:51 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
