LET'S FIND OUT WHATS The BEST GAS 4 THE MOST MILEAGE ON 02TL???????
ACURAZ4EVER
I Always wonderd what's the best gas to use for TL we all know its 91 but is it SHELL? ARCO? 76? MOBILE? OR WHATEVER IT COULD BE ??? LET FIND OUT
1. YEAR AND MILES ON CAR ( 02TL 45K or 02TLS 45K)
2. WHAT COMPANY and TYPE ( ex. 91 SHELL)
3. CITY/HIGHWAY or FREEWAY ( 60%/40%)
4. How Much you get out (ex 240-260)
ACURAZ4EVER
Mine experiments were the folowing
1. 02TL 41K
2. shell 91
3. 25%/75%
3. 278 ( low fuel came up around 245)
1. 02TL 41K
2. Shell 91
3. 50%/50%
3. 250-255 ( Light comes up around 225)
1. 02Tl 42k
2. Mobile 91
3. 50/50
3. 240 light comes up around 215
1. 02TL 41K
2. shell 91
3. 25%/75%
1. 02TL 41K
2. Shell 91
3. 50%/50%
1. 02Tl 42k
2. Mobile 91
3. 50/50
IMO, 91 octane fuel, is 91 octane fuel, is 91 octane fuel. Any differences is due to the hwy/city driving percentages or how frequently someone has their foot in it.
I track mpg on every tank and I consistently get 21 - 22 mpg.
it all depends on where you live.not all the fuel across the us is the same.
i just drove 453 miles to a tank and filled it up and put 13.87 gallons in with 76, 93 octane. it was 98% hwy.
typically you will get less mileage in the winter due to the winter blends. i know i see atleast a 50-90miles less per tank difference in the winter
Boomer SOONER
i have a 2001 tl with 74k miles
i use 93 octane gas from shell (down here we only have 87,89, and 93, no 91)
i get about anywhere from 280-305 miles per tank, and i drive about 30% highway, 70%city.
i used to get about 270 miles before the light turned on, but i moved out of the suburbs....
1. 02TL-S, 55K
2. Exxon 91
3. 30/70
4. 340-350
average 25mpg the majority of the time but then again I don't floor the TL unless I need to
I can get more than 30mpg on long hwy trips to San Antonio
2. Exxon 91
3. 30/70
4. 340-350
wow.. but youre in warmer places. Im only getting 215-230 no matter where i fill up. freakin winter weather is KILLING my gas. but thats WAY better than the freakin nissan Z im SHOLDNT be driving all the time. i switch around but Z's are just so much fun on warmer days.. being all cold right now im sitting at the gas station every three days! pissing me off. i need to move to the south or the west.
Received 2,329 Likes
2003 TL
400 miles or more until the gas light.
I tend to get 31 to 33 mpg. Mostly freeway.
BTW, regular gas. Premium is only an absolute on the Type S.
My 1999 TLP Owner's Manual says. "Your Acura is designed to operate on premium unleaded gasoline, with a pump octane of 91 or higher. Use of a lower octane gasoline can cause a persistent, heavy metallic rapping noise in the engine that can lead to mechanical damage." Sounds absolute to me or are you referring to TLPs from other years?
Example:
2003 - 2005 Accords J30 engine runs regular just fine. But.. it will take premium and GAIN horsepower (about 10 or 15). This is straight from the mouths of Honda engineers. So do a reverse of that. 225 hp - 10 or 15 hp = 215/210 hp. I can accept that. These engines run on a decent compression ratio and are advanced enough to accept all types of octanes without harm.
You only need premium in your TL if knocking occurs but I really doubt it will. Again, Type S TL's are a different story as they run higher compression.
As for my '97 TL, I run premium in it.
Originally Posted by alleyesonmeee
Thats not very good gas mileage....
Boomer SOONER
even on tanks where Im 100% in the city...just to and from school and around town, I always get 290-310 miles - but there was 1 time that I got around 210, must have been shitty gas or something...it was right when they started using the winter blend, maybe the car freaked out.
I have to drive in heavy traffic to school in the mornings, I don't get above 30 mph in stop and go for about 10 miles. I've never gotten below 350 to a tank except for when my car had a problem.
trill recognize trill
Originally Posted by fsttyms1
Originally Posted by yunginTL
what can i do to improve it last 2 full tanks i used the techron fuel cleanin shit what else is there to do? tires are okay
Also you could try some fuel injector/fuel system treatment. It will get bad gas mileage on the tank that you add the treatment to, but after that it should improve.
wow. umm i take care of my car. i do all that, but i usually get close to 300 during the summer. the winter is a huge impact on my car. it drops from 300 to the tank to about 210 during the winter. ITS ANNOYING. i only drove the Z in the winter.. since its pretty new so i dont know how much that gets during the summer. its supposed to be 19city/26hwy
It could be from winter gas blend, and also try filling your tank up at different gas stations to see if your car likes one type of gasoline more than another. Clean your throttle body, or it could also be an 02 sensor. I think you should keep track of the gas your car uses for about a month or two...gallons of gas you put in your tank, miles on each tank, and how much it costs you each time you fill up. That way you can bring it in to a Acura dealer or mechanic if you keep getting lower than normal gas mileage. They will know the exact mpg you are getting, and they could tell you if it could be a problem or not. You probably shouldn't be getting lower than 18 mpg.
gotta link to any1 that did it?
WDP Is Faster
-2002 TL-S w/ 28,000 Miles
-Some uknown gas station (Kwik-Mart a.k.a. Kwiki Market), 89 octane
-10% City/ 90% Highway
- Around 386 miles @ 1 Tank. (Could've been higher)
I thought my gas mileage sucked.. well.. I drove from the Bay Area down to Santa Barbara with a full tank of gas and I had even more gas left when I was actually down there. I filled it up with just a lil amount of gas left in the tank (no light on). So..I'd say..if I kept on going..I could've made it to close to 400 miles MAYBE..
I did not floor the car one bit during the trip with the full tank of gas and I was averaging abaout 75mph on the highway with no SS mode throughout the whole time.
BUT..when I was coming back..I was going at an average of 90 MPH (Hit +100MPH couple of times) and got 21 MPG HAHA...
1. 00 46k
2. shell/sunoco 93
3. 10/90 c/h
4. ~350 then usually refill
ive been bouncing back and forth between sunoco 93 and shell 93(vpower). i get 24-27mpg consistantly. i dont think ive ever been below or above. ~25mpg i can live with, more the better of course
2. shell/sunoco 93
3. 10/90 c/h
WDP Is Faster
Originally Posted by Shift_it
I use regular unleaded 87 octane. Seems to have very good performance. No ping like my old Maxima SE did when I owned one.
Who's with me on 87 oct ?
wow.. i get half the mileage most of you people get.. i need to get out of this crazy cold winters of the northeast.. its killing my car and my gas mileage. not to mention the freakin salt buildup and snow messed up my paint.
Honda+Blue=My garage
02 TLS
Grocery Store (Tom Thumb)/93 octane
75% hwy/25% city
340-390 miles per tank-usually fill up just after light comes on around 320-340 miles--avg 23-25 mpg
75% hwy/25% city
WDP Is Faster
Originally Posted by reloaded
I hope you don't have a TL-S...because if you do..you're gonna screw up your car if you use 87...
Nope just a plain 99 TL. No need for another letter on my car
It could be your driving too. I know for me, I use to (still do) like to gun the car from street to freeway all the time. Then I would gun it around the freeway because it felt so fun..but then it was a killer on the gas mileage. So when I was on this Santa Barbara trip..and I actually drove like a decent human being, I got such a high mileage that I even shocked myself lol.
USDM UA5 A-Spec
Clean CAI (Summer)
1. 02TL 45k
2. 91 Chevron/76
3. 80% highway 20% city
4. 310-330
Dirty CAI (Winter)
1. 02TL-S 48k
2. 91 Chevron/76
4. 280-300
I only trust Chevron and 76... Shell has been bad for my car lately. No ARCO cuz i use my credit card.
1. 02TL 45k
2. 91 Chevron/76
4. 310-330
Dirty CAI (Winter)
1. 02TL-S 48k
2. 91 Chevron/76
4. 280-300
NiGhT rIdEr
