LED's are flickering...
The last two or three weeks have been disappointing. The LED I put in my dash have started flickering and then staying off.
First it was the far right bulb on my odometer.
Then the buld behind the tach.
Now the buld behind the gas/temp!
What the heck is causing this?
I would understand if they just went out (although they are supposed to have a longer lifespan than a couple months),
but they flicker rapidly and eventually slow down until they stay off.
It seems to cycle the same process again everytime I start the car.
Would it be the cold winter weather? Or the heat from the heater?
Maybe the contrast from the cold to heat everyday to work?
I have these blubs from autolumination.com installed:
http://superlumination.com/images/au..._3led_w_wm.jpg
Any idea?
Anyone have the same issue?
Any idea?
Meridian
I had the same problem, but not anymore, this should help (this is from an email they sent me):
If the led are burning out you need to make some changes.
There are several causes of voltage related failures on leds. Some vehicles chronically cause premature led failures. This is normally related to excess voltage, voltage spikes, or high levels of AC current being generated from the alternator. While glass bulbs are slow to react to rapid surges, leds can be destroyed in milliseconds from a sudden spike or chronic high voltage, or excessive AC current from an alternator that has one or more burned out diodes.
If the bulbs are being used in gauges with a dimmer, always set the dimmer to 80% or less. This minor adjustment will make the leds last ten times as long in some vehicles with chronic voltage issues.
If the bulbs are being used in an application with no dimmer, we have a new led protector that can be spliced into the + wire to protect against minor voltage surges. These work great in vehicles that have high voltage, or are prone to voltage surges. They can also help protect the leds from:
1. Switching on the ignition & starting the engine.
2. Changing or disconnecting the battery.
3. Charging the battery with an auxiliary battery charger, or revving the engine hard with a weak or dead battery.
4. Using jumper cables.
Eggs999bacon
09-24-2015 10:08 AM
