LED for Interior replacement??
I was wondering there is a site LED automotive and it has TL replacement with LED lights but it shows that you can change the dome/door/map lights under the honda section but they are similar to the TL I was wondering if they are the same. They are replacement bulbs but they have LEBs inside the bulb. Thanks.
NiGhT rIdEr
try this site out----> http://www.ledautomotive.com/OrderIn...cord/index.asp
i think this place might sell snap in replacements...
i'm looking to do the same thing.
http://www.autolumination.com/
Thanks alot I plan on ordering blue and white to see whats brighter. What do you think about fogs I don't buy all this stuff stating that brightest white nothing can match the HID. But have you found anything close? Thanks
Initial D
Originally Posted by MikesTL03
Does anyone know if Hyper white is Bright for Dome etc?
LED thread
woooo!!
Originally Posted by TunedTL
Unfortunately no, see the thread. I would wait until someone come up with a 9LED for our dome light.
LED thread
LED thread
I bought a 4LED 31mm light (i followed the bulb # from replacement guide) but turns out there is a lot of room left for a longer one. After measuring from with a ruler... turns out there is about 37mm of space, and since end power connectors are slight malleable, wedging a 39mm up there shouldnt be an impossible task.
Next time I order from autolumination, I'll order one and keep you us informed...
btw regarding thread topic, you should be aware that single-bulb LEDs are nowhere as bright as the stock incandescent... the multi-bulb LEDs, however, might come close. I haven't seen any in action to make the call.
handsom-hustla
11-13-2015 05:04 PM
asahrts
09-04-2015 05:55 PM
