Leaking 03 TL
Leaking 03 TL
03 tl every heavy rain we get . My floors get a little damp but my main is my fuses start blowing. Radio, instrument cluster ac fuse. It never fails of it rains I'm replacing fuses. My sun roof drains are fine and draining . It's also not leaking from the sunroof into the roof. Is their any way out child be leaking from the vents by the wipers and running down the inside of the fire wall. I'm in Florida I've only able to drive this car 3 days the last 3 weeks .
I think this is so open a question that nobody wanted to chance and answer. It is always possible to get a leak if something rusts out. Being FL that would be common. If this was my car I would open up the dash as much as reasonable, take a bucket of water and add some food coloring that you think would be easy to spot if it was dripping down on the inside of the car and pour that water over sections of the car to see where and when you spot a leak. Given the fuses blowing I would put some paper towels over the fuse box area and check it often after pouring a bucket of water over a section of the car. Good Luck.
