Leak at the transmission seal
I've read similar threads, but had a more specific question for the AZ folks: I'm about to get my timing belt replaced, when this week I notice a leak
It's coming from the drivers side axle at the transmission joint.
Is this a normal wear item? I have had zero noise and the boot is AOK, so I don't want to replace the CV axle if I don't need to.
I already got a quote for the Timing belt from a shop in the PDX metro area (in Vancouver and an AZ reader), should I add the CV seal to the mix?
Thanks so much - I have never been near a dealership since since I joined this forum
is the boot torn or signs of the actual CV grease getting out?
Or is it really ATF? reddish fluid
there is a seal there where the axle goes in
can fail on its own, but have the axle ckd- if its moving around it can wear the seal
cv bearings do wear out
absolutely get any leak fixed!!!
a brand new axle assembly from NAPA is around 100$
Advice taken
I'm borrowing a late model Corolla with the .018cc Hamilton-Beach blender motor, so you can guess how much fun that is to drive. It makes a mean margarita, but you have to pretty much floor it, then rock back-and-forth to get it up to highway speeds
IBankMouse
06-13-2020 12:53 PM
joflewbyu2
10-08-2015 11:16 AM
flyromeo3
09-24-2015 11:24 PM
