Langka?
![Thumbs down](https://acurazine.com/forums/images/icons/icon13.gif)
I tried 4 times already to remove the blob on my touched up scratches on the Miata...First three times, I waited the 90 minutes that they suggest to wait. Every time I tried to remove the blob around the scratch, the paint would come out of the scratch too.. Someone on the board with experience with Langka suggested I let the touch-up paint dry for 2 days, which is what I did, and still, no positive results..Not only did it remove the paint around and in the scratch, but it also removed the pinstripe I had on the car! I had a silvery-white pinstripe running from front to back of the car, and then this nasty aqua green scribbly pinstripe in the center of each doors... On a good note, I finally figured out how to remove the nasty aqua pinstripe, but I wanted to keep the silvery-white one...oh well.. I ended up Langka-ing the pinstripe all around the car and it came off like nothing...so now the car's pinstripe-free! I don't know if I should be happy or sad...
Ed
Acura-TL.com - Forum Moderator
'66 Mustang Fastback
'99 Mazda Miata
'99 Acura TL Satin Silver/Ebony, Non/Nav, Comptech Springs and Sways, CL Type S wheels wrapped with 225/45/17 Dunlop SP9000's, Comptech Air Filter Element, Inspire Tails, AEM Brake Pads all around, Comptech Axle Back Exhaust, Gutter Guard Grille, "Guy Smiley" doll on the dash as my Co-driver...
Pics of my TL
Pics of my Miata! Wadya think?
Ed
'99 Mazda Miata
Pics of my TL
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
You should be happy b/c #1-you didnt scratch the Miata and #2-those awful green squiggles are gone. ![](http://www.acura-tl.com/ubb/biggrin.gif)
Tom
2001 Nighthawk Black Pearl TL
Comptech springs,Xephyr,Performance CAI, Inspire tailights,Piaa super white 001 solitare fogs, Inspire fog switch,Burlwood shift knob,Piaa Xtreme white blinkers,Razo carbon fiber pedals,BEL 870 radar detector, Acura-TL.com sticker
Tom
O.G.
Hey Ed, I also have Langka. I tried it once a few weeks ago but nothing happens. I don't know if I did it right or the shit is not working. But I met j83 at the Park Ave Acura meet and he said that Langka really works. He showed me the spot where he used Langka and the blob was not there. So I am going to try again and if it fails then I am going to take it to his house for him to do it for me. ![](http://www.acura-tl.com/ubb/biggrin.gif)
Binh
Binh
![](http://planettribes.com/havoc/ac/blackshadow.jpg)
Maybe the whole paint comes off because you didn't clean the area thoroughly before applying the paint? I was gonna buy lanka...cause I got a few dings too...hmmm. Anyway...try wiping the area clean with some alcohol first...and put some primer too
Received 1,080 Likes
Langka does work. The key is to really clean the chip well. I use paint cleaner, but I guess you could use rubbing alcohol.
Make sure the crack is free of any loose paint. Take a pin and pick away at any loose paint. Small chips are hard to do. Sometimes I make the chip larger so the paint has something to hold on to.
Let the touch-up paint dry pretty well. Use VERY LIGHT PRESSURE on the Langka when you rub. Too much pressure and you'll remove all the paint.
Only got exp. Langka is not perfect , but it sure as hell beats having blobs on your car.
may be it just works good w/ my white paint.
CL-S
White/Ebony/Navi/Spoiler/Visor/Full Bra/Mud Guards/Cargo Net/Acura Car Cover/Tint 20%,35%, Rockford 250a2 Amp w/JL10w6 / K&N Drop in Filter. Comptech Springs/Sway/Headers Polarg m-6.
CL-S
I got these instructions from their website - you may already know this but just in case.
STEP 1: Wash and dry your vehicle. Clean chips with rubbing alcohol.
STEP 2: Use a toothpick, matchstick or brush to apply manufacturers touch-up paint to the chip. Allow it to dry to the touch — typically 45-90 minutes. This will leave the typical "blob" of touch-up paint visible. Apply 2nd or 3rd coat if necessary.
STEP 3: Wrap a smooth, clean, tightly woven cotton cloth around the enclosed "buffing card". SHAKE WELL and apply LANGKA generously to the flat surface. Rub LANGKA over the "blob" for 15-30 seconds allowing LANGKA to quickly penetrate and begin smoothing the "blob" of excess paint. Once the touch-up paint blob begins to wear off, begin rubbing lighter until the excess paint is gone and paint is left inside the chip/scratch. Lightly hand-buff to remove any excess LANGKA with a clean cloth.
O.G.
Originally posted by eclipse23:
I got Langka too and I can't seem to use it right! Care to take a drive BlackShadow? I'll follow you!
I'll let you know if I decide to drive to his house.
