Kaaaaaaabooooommmm!
Old Aug 27, 2009 | 04:54 AM
MyPearl02's Avatar
Kaaaaaaabooooommmm!
to make a long story short i threw a rod through my block yesterday morning
Old Aug 27, 2009 | 06:35 AM
juanclopez2786's Avatar
damn sorry to hear that... howd that happen?
Old Aug 27, 2009 | 08:16 AM
6MTUA5's Avatar
No He Can't
haulin ass?
Old Aug 27, 2009 | 08:20 AM
FirePR2002's Avatar
bringin lead
damn it. new engine or repair?
Old Aug 27, 2009 | 08:33 AM
6MTUA5's Avatar
No He Can't
Usually a hole in the block means new engine
Old Aug 27, 2009 | 08:43 AM
fsttyms1's Avatar
How did you manage to do that?
Old Aug 27, 2009 | 09:38 AM
phee's Avatar
I got the Shifts
low oil or blown headgasket?
Old Aug 27, 2009 | 10:23 AM
nhn23's Avatar
I live in
x2
Old Aug 27, 2009 | 11:32 AM
01tl4tl's Avatar
supercharger??
Old Aug 27, 2009 | 11:34 AM
Aman's Avatar
Your Friendly Canadian
Overrev? maybe rev limiter isn't working?
But damn, I didn't know that was possible. All you have are headers, a catback, and a CAI.
Old Aug 27, 2009 | 11:44 AM
6MTUA5's Avatar
No He Can't
Old Aug 27, 2009 | 02:28 PM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
Yeha let us know how that happen so we can make sure it does not happen to any of us!
Old Aug 27, 2009 | 02:41 PM
totaledTL's Avatar
Old Aug 27, 2009 | 05:01 PM
MyPearl02's Avatar
sorry i dont have any pics of it i got on it but not to hard and a loud bang came then the car started to run like shit and shake so i drove it for two blocks and turned on a side street and she died but the motor is cooked they got the new one today and will have it done for me tomorrow or saturday
Old Aug 27, 2009 | 05:17 PM
StonedCL's Avatar
B A N N E D
WOW that did not answer one question!
Where u driving when u heard the bang or was it parked?
How fast where u going if u were moving?
Do the mecanics know why it happened?
Do u have and mods, CAI , headers , turbo, NOS??
Old Aug 27, 2009 | 05:55 PM
phee's Avatar
I got the Shifts
Broken timing belt
Old Aug 27, 2009 | 06:41 PM
01tl4tl's Avatar
that will bend valves for sure, but have not heard of rod thru block as a result of tbelt? anyone else seen that? kris?
A broken lower rod bearing cap would do it or a piston wrist pin could break and kaboom
The engine should take full throttle with the listed mods--
supercharger is the only way I have seen to really pop the motor good since the 80s
Oil pressure?
Another good reason to seafoam the oil-- remove years of sludge from the oil gallies and vtec operating system--which uses oil pressure to operate
TV connercials are not kidding about engine sludge
Old Aug 27, 2009 | 10:44 PM
TX-Miner's Avatar
To paraphrase Cale Yarburough, "She was running great and all of a sudden she blew up." Of the 3 thrown rods I've seen, my lawn tractor and a friend's Volvo were the result of low oil issues. A 1970's Oldsmobuick was being driven a bit aggressive (100 mph) and the engine just gave up.
Miner
Old Aug 27, 2009 | 11:22 PM
Aman's Avatar
He "got on it" so evidently he was moving. That's one question. And if he "got on it" engine speed would be more important than actual speed, and he was probably revving pretty high. Mods are listed in the sig. That's 3 right there.
But I'm also curious as to why it happened.
Old Aug 28, 2009 | 12:15 AM
TouringLow's Avatar
that's cool, thanks for sharing.
Old Aug 28, 2009 | 12:32 AM
Edward'TLS's Avatar
6G TLX-S
Originally Posted by phee
Broken timing belt
x2.
Old Aug 28, 2009 | 04:24 AM
01tl4tl's Avatar
no reply and explanation from OP? must be a scam~
Old Aug 28, 2009 | 08:27 AM
phee's Avatar
I got the Shifts
i say its a broken timing belt and he was just assuming he shot a rod
Old Aug 28, 2009 | 01:05 PM
rod through the block wouldnt drive 2 blocks and then die. and if i were him id have mad pics of it lol... cant do anything but laugh.
Old Aug 28, 2009 | 02:07 PM
twistedwedge's Avatar
6MT Someday..
You would really have to be overreving the engine to toss a rod with the engine being stock...what did your rev limiter malfunction and you shift it at the top of the tach? (what is it like 9k?)
Ive seen turbo, nitrous and s/c engines do it, but not a stock engine
Like others stated-Im sure it was the timing belt letting go. It can be pretty catastrophic at high RPM when it happens...
Old Aug 28, 2009 | 02:12 PM
fsttyms1's Avatar
Oil pressure?
Yes i have seen it. I have done it.
Judging from the stoutness of our rods/crank/caps, smething had to just be a rare freak break. Also how would you drive for 2 blocks with a thrown rod.?? My guess is a timing belt broke.
Old Aug 28, 2009 | 02:17 PM
Aman's Avatar
More motivation to get that service done.
Old Aug 28, 2009 | 09:51 PM
TX-Miner's Avatar
The Oldsmobuick I mentioned ran suprisingly good on 6 (of 8) cylinders. At first I thought it was merely a broken valve rocker (push rod engine) or bent push rod, but when I removed the intake, the small end of one of the con rod was sitting where the 7-8 camshaft lobes used to be. The engine started, and other than the knocking caused by the remaining 1/2 of the con rod banging the block, ran fairly smooth.
Miner
Old Aug 29, 2009 | 11:42 AM
MyPearl02's Avatar
well it wasnt the timing belt that broke so thats out of the question. they told me that it was an internal failure and the the oil level was fine. and after she went i looked under the car to see oil just pouring out and the tech told me there is a hole in the back of your block. the car started up in the shop but only ran on two cylinders.
Old Aug 29, 2009 | 12:37 PM
fsttyms1's Avatar
Well thats a first that ive seen from a J32
Old Aug 29, 2009 | 12:38 PM
if there was oil pouring out the block when it went how did they know the oil level was ok in the shop??
Old Aug 29, 2009 | 01:56 PM
MyPearl02's Avatar
because i just changed the oil 200 miles prior
Old Aug 29, 2009 | 02:18 PM
ok so let me get this straight... ur driving along and all of the sudden kaaaaaaaaaboooooommmm and u drive 2 blocks pull over and "went i looked under the car to see oil just pouring" and the tech says "the oil level was fine" and ur able to still turn the car on hole through the block and all.... thats an awesome j32 u have my friend
Old Aug 29, 2009 | 03:00 PM
DaveS221's Avatar
lmaooooooo yungunz hahahahaha
