Just wanted to confirm a couple of oil change steps
should i let the engine run for a couple mins 1st before draining the oil out? or is it ok if the engine (and the oil) is cold?
and i've read you should also either take the dipstick out or take off the oil cap so the oil will drain faster? is that true?
I do the same. Remove oil cap, but not dipstick. Be careful when you make it too hot. When that oil comes out, pours on your hand and down your arm, it's not to plesant.
another thing...are you supposed to unscrew the drain bolt clockwise or counter-clockwise? cuz i can't frickin get the damn thing off. i am using a 17mm socket which is the right size. i also tried WD-40ing the bolt, but it won't come off! it's pissing me off! HELP!!!
use a 1/2 socket wrench with 17mm socket and give it a good tug counterclockwise (facing the bolt)
finally i got the fvcker off. my 1st own oil change wasn't too bad, but it got real messy when i took the filter off. besides, that it was simple as everyone said it'd be. but the real surprising thing is that when i was emptying my oil pan container with the old oil back into the empty 1L bottles for recycling, i only got 3 bottles full! either those damn no-good acura mechanics didn't put in the required 4.6 quarts (~4.35L) of new oil only 6000 km ago in june or oil does evaporate that fast which i can't believe. what's the least amount of motor oil our engines can go on? cuz i sure hope those 3L were ok.
Some oil can accounted for in the old filter, maybe up to 1/2 a litre.. and if you were a little low on oil before the change and if the car was not on a big enough incline there will be a little oil left in the sump.
J
J
well i'd say the oil that gushed out when i took off the filter including what was in it was maybe around 1/3 of a litre. that's still a lot of oil left in the sump. but this got me thinking. despite the manual stating to fill up the engine with 4.6 quarts (4.35L), is it absolutely necessary? i think putting in just 4L will still keep you between the min & max lines on the dipstick. that way, i don't need to get a 5th bottle (1L) of oil. just a 4L jug is ok.
mada51589
05-03-2022 08:54 PM
Zonian22
11-14-2015 01:20 PM
Skirmich
09-15-2015 06:41 PM
