Just installed Philips Ultinon 6000k's TAKE A LOOK!!
Hey, I actually installed these about a week ago, but I'm just getting around to posting pics. These are pics of the install (left headlight is stock, right headlight is 6000k) and I just took these so all you guys can compare. If I get around to it, I'll snap some pics of both 6000k's which are in, tonight. Hopefully I can get the pics to work
Oh, and yes, I know that my hood is partially open
![](http://www.acurainspired.com/gallery/showpic.php?uuid=1269&aid=1714&pid=37216)
![](http://www.acurainspired.com/gallery/showpic.php?uuid=1269&aid=1714&pid=37217)
![](http://www.acurainspired.com/gallery/showpic.php?uuid=1269&aid=1714&pid=37218)
![](http://www.acurainspired.com/gallery/showpic.php?uuid=1269&aid=1714&pid=37219)
If the pics didn't work, here's a link to the gallery.
http://www.acurainspired.com/gallery...1714&uuid=1269
LEMME KNOW WHAT YA THINK!!!!!!!!!
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
hahahaha I paid $245 shipped from Akinaboy...pm him, he's great to deal with!!! Oh, and I know I need a car wash, it's all that dang salt thanks to the crappy central NY weather!!!
Wow.. big difference between standard and 6000k.
I have 8000k on my tl and the color is too purple/pinkish and one of them burned out after 2 months, so looking for a set of 6000k philips ultinon bulbs. Where did you get your bulbs and for how much? how's quality compare to stock?
thanks
p.s. = great pictures.
thanks
Damn they look way brighter than stock. But are they actually brighter in terms of light on the road? I see it as 6000k being a nicer color than 4100k but 4100k should give the best light output but looking more yellowish white. I love the 6000k color though...Please take some pictures of the light output on the road somewhere with no street lights. Great choice on the bulbs nonetheless.
thanks
thanks
Originally Posted by bdv687
I personally think that in addition to better color, the light output is also better. Yes, you will get a little bit more glare, but it lights up things further down the road. I got them from akinaboy [mod edit]
I guess it was a wise investment?
05 C230K & 09 135i 6MT
Actually, as far as illumination, it doesn't get any better than 4100-4300k. 6000k is minimal loss of useful light for the added color, but stock is better for illumination.
Thanks for your help.
Originally Posted by phins2rt
Did you get D2R or D2S bulbs??
Can yo help me out with replacing my Headlights?? I have been searching throughout this forum and I haven't found any posting detailed enough. For example, when I open my hood there is a bunch of crap blocking access to the driver's side headlight. I need to know what I can remove and how to access the bulb. Also, I bought the tamper-proof torx screwdriver. Will I need anything else. I am currently away from my home (and tools) but I need to get this bulb replaced asap before I go on my long road trip back home.. Please pm me...Please....
BDV687,
Can you help me out with replacing my Headlights?? I have been searching throughout this forum and I haven't found any posting detailed enough. For example, when I open my hood there is a bunch of crap blocking access to the driver's side headlight. I need to know what I can remove and how to access the bulb. Also, I bought the tamper-proof torx screwdriver. Will I need anything else. I am currently away from my home (and tools) but I need to get this bulb replaced asap before I go on my long road trip back home.. Please pm me...Please....
Dont use headlights for several hours
DISCONNECT BATTERY NEGATIVE ~~~know radio security code first-
driver side- pull the upper cover plastic and the overflow bottle if needed to gain access- then use the torx to remove the 2 funky screws
inside that cover there are the bulbs attached to a normal plug-in connector for headlights
Be very careful with the new bulbs- use rubber or latex gloves to handle
no skin oils to bulb contact allowed!!!!
if not using D2R the oe standard- if they are the universal D2S- be careful not to twist the bulb as you install
the oe bulbs had a detent that lined them up- some replacements dont- so note position of external rod on bulb as you remove- install new one same- no twisting
NOTE the bulb assembly is held in by a 1 armed spring clip- needle nose pliers help to grab- unlock and release that- dont break- vital for assembly
Place bulb in socket, spring clip- connector- TEST- cover - done
10-20 minutes max
10-20 minutes max
10-20 minutes max
10-20 minutes max
10-20 minutes max
10-20 minutes max
I will install them as soon as I get my new bulbs. I purchased Kaixen 6500K....Based on my reading other threads, it is highly recommended, right?
I am running kaixen 6000k - excellent- best lights I ever had- I laugh at other cars lights as I pass them
be really careful installing them- do not twist!!!!!!!
Josh-Excelerate will happily remove 150 of that burning wad and trade you for a set of awesome lights
Kang Ho
Originally Posted by orgnlprankster7
^^ i keep hearing how great these are, now im gonna have to go get some. i have money in my wallet and it feels weird so i have to get rid of it asap ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
-Arsenic-
Originally Posted by bigeshorte45
why have i not seen a pair of eyelids for my 02 tl type s???
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
![](http://www.andysautosport.com/images/detailed_product/exterior/accessories/eyebrows/saro_ac-005-el.jpg)
Originally Posted by 02type-s
Would you say the color is closer to purple or blue?
-Arsenic-
Originally Posted by fsttyms1
Screw color. Get the ones that give you the most visibility ![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
