Just finished Installed AEM CAI
Go Stros!
I just installed my AEM CAI two days ago... I ran once for one day without resetting my ECU and it felt good. But when I resetting the ECU...Man, my car picks up now..I like it...All I need now is some headers and I'm good. But yeah, I just wanted to share..if you guys haven't gotten a AEM CAI...I highly recommend that you do...Best $200 I spent so far on my car. Alright then..I'm out.
yeah i'm bored.
did resetting the ecu really make a difference? i installed the cai months ago, never considered resetting the computer though. it just involves unplugging the battery, right? maybe i'll give it a shot.
Go Stros!
Yeah, when you unplug the battery remember to unplug the negative...Yeah, well it felt a little better..It is not like it is that dramatic, but it can be felt. Try it
resetting ECU
nowadays ECU's are getting smarter (about time...)
what happens by resetting the ECU is that the car basically starts out with a fresh clean slate... which gives it the opportunity to adapt and learn how to make use of the new add-ons.
the ECU is designed for efficiency... and as you drive the car over time, the ECU will figure out your own specific drive patterns and optimize natural settings.
again... gains are small... but small gains are what add up.
2 cents for free.
2 cents for free.
Yeah, make sure to turn on the lights or step on the brake to drain the leftover charge in the car's system if any after you unhook it. Just make sure that there is no current draw when you hook back up.
Originally posted by kgoessling
Please enlighten a novice, what is a CAI?
Thanks,
Kent
Thanks,
Kent
There are two basic intake designs for our J series engine...
1. Short Ram Intake
2. Cold Air Intake
The difference between the two is design, and performance...
Short ram doesnt extend down to the wheel well, there fore you wont get as much performance as the cold air setup (due to the fact that your engine will be heating up the air your intake induces) Cold air intake induces "cold air" from underneath your engine.. closer to the left front wheel right under your left headlight..
but there is a significant gain over the stock air box...
1. Short Ram Intake
2. Cold Air Intake
cycdaniel
12-17-2019 10:58 AM
BoricuaTL
04-08-2016 01:08 PM
InFaMouSLink
10-27-2015 06:51 PM
Abe_Froman
09-16-2015 01:27 PM
