Just clocked 150k
Just clocked 150k
Whats up TL. Just hit 150k in the whip. Was just curious, what do you guys recommend changing around this time?
I already recently did my brakes and timing belt. I want to keep her on the road until she falls apart!
Was thinking of doing my spark plugs, but decided to just make a master list of things to change so I can do it all in 1 weekend. Thanks!
The plugs, pcv valve, check motor mounts and replace all if engine moves too much, clean whole intake system with egr port holes, iacv valve, throttle body, egr valve and main egr passage on block, change external tranny filter, cabin filter, change thermostat and upper & lower rad hoses, rad cap, flush cooling system, flush brake lines.....
