Just changed my Tranny Fluid
Old 07-01-2012 | 10:44 AM
  #41
Sperry's Avatar
2000 TL Black on Beige
Originally Posted by texholdem
apart from on a level surface how do you check the atf level correctly? with running engine? hot atf? in P or N position?
Thanks!
I check mine after the car has been sitting overnight.
I've never added more than three quarts during a D/F,
and it always reads between the dots.
Old 07-01-2012 | 10:49 AM
  #42
webmastir's Avatar
2003 TL
Well checking when engine is cold is the wrong method. I believe you need to go drive for ~10~15 min, pull over & then check level of fluid on level surface.
texholdem (07-02-2012)
Old 07-01-2012 | 11:47 AM
  #43
Sperry's Avatar
I just checked the manual, and it does indeed state the car must be at "operating temperature".
The level is at 6/10ths between the dots on a 95˚ day.
I'll get back to you as to how much it expands, but I'm pretty sure it doesn't go over the top dot.
Old 07-02-2012 | 07:07 AM
  #44
texholdem's Avatar
meaning with running engine and in P position? Thanks!
Old 07-02-2012 | 08:17 AM
  #45
Sperry's Avatar
1. Park on level ground. Shut off the engine.
Old 07-02-2012 | 11:24 AM
  #46
texholdem's Avatar
Originally Posted by Sperry
Thanks! I bought my car without the manual. It's high time to look for one, just wonder if there is the manual in electronic format to download.
Old 07-02-2012 | 11:26 AM
  #47
webmastir's Avatar
2003 TL
http://www.bookonlinepdf.com/2003-ac...ers-manual.pdf
texholdem (07-03-2012)
Old 07-02-2012 | 02:05 PM
  #48
Sperry's Avatar
I'd bet bottom dot cold = top dot hot. I just checked after a 30 mile errand, and I'm all of 2mm over the top dot, if that. It might even be less, because the fluid sloshes around when being pumped through the system, and the inside of the dip tube may receive fluid.
In the beginning, I heard everything about "measure exactly what comes out", etc etc etc.
Well, if the wrong amount is in there coming out, you wouldn't want to put the wrong amount in.
I'm happy with 3 quarts out, three quarts in. Seems like it works perfectly.
Maybe, for whatever reason, some cars may be 3.1 or 3.25 quarts per D/F.
Old 07-02-2012 | 04:47 PM
  #49
03tl-s04mdx's Avatar
Register online at www.owners.acura.com and you can get the manual in PDF plus all the current recall info for your specific vehicle.
nanos
11-12-2015 08:41 PM
HydrasunGQ
09-14-2015 10:14 PM
HeloDown
09-08-2015 06:51 PM
jfman55
09-05-2015 02:55 PM
quake97
08-30-2015 07:57 PM
Quick Reply: Just changed my Tranny Fluid
