Just about sick of my car
Well, I'm sick and tired of its problems.
I'm getting severe vibrations in the front of the car that I have been battling for the past couple of weeks. I just had the right side CV joint replaced which did not solve the problem. I swapped tires with no success.
It's very, very weird and the shop that worked on my car is not 100% certain. They said it was a tire separation issue at first, then came back and said it was the CV joint. I've replaced the CV joint and swapped tires to no avail.
Under acceleration, the steering wheel vibrates a lot. Under moderate to heavy acceleration, it almost feels as if the front right wheel is hopping up and down. During left turn corners, the front right exhibits the same symptoms.
This is driving me nuts.
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Shock or motor mount.
At this point, I am leaning toward engine mounts.
I've called the shop to discuss the matter, but the owner still has not called me back. I wasted over $200 and replaced a perfectly fine OEM CV joint for an aftermarket one based on their misdiagnosis.
I don't think it's a bent rim or tire separation. The vibrations get worse under acceleration and subside once I'm off the throttle. If it were a wheel or tire issue, it would be constant.
Lamborghini Aventador FTW
A quick way to check if it is a blown engine mount is to get a buddy to rev the engine in park while the hood is open and you are looking at the engine. If you see the engine move more than you'd expect, that is usually a sign of a blown mount. Not necessarily a tell-tale sign, but you can get a good idea.
if you feel your car is vibrating then it's gots to be a engine mount if it's your stearing wheel vibrating then check your suspension/tires.
Check your hub rings if you haven't since it seems you've checked everything else.... it's a quick and cheap fix if it is. i noticed i had this problem after mounting on my Volks when going past 50km/hr i could feel the vibration. couldn't figure it out for a week... had the tires remounted and balances and everything... finally changed out the hub rings and the problem was solved.
No He Can't
Originally Posted by fobstylez
I think you should take it to the dealership, have them test it and found out the issue, THEN take it to a smaller shop to get that done. My 2 cents is mounts as well
I vote for a bad shock, or perhaps a bad wheel bearing. When you say vibration on the steering wheel, do you mean shimmy back and forth of the wheel? I would have the shop check all the supspension mounts and bushings. Because you seem to have the same symptoms when turning left, I would look away from a motor mount issue and towards suspension.
Miner
Miner
"Steering wheel vibrates" - suspension issue, usually - except the rack is mounted to the engine subframe, right? If the Right engine mount is bad, that'll move the rack as well, so you'll feel it in the wheel. My $$'s on the engine mount....
TL-S driver
My guess on motor mounts. I had the same problem and I actually thought my wheel was going to fall off. I tourqued them, balanced my tires and even thought it was the tranny again. When i had it at the dealership to get the timing belt done, they said i had a blown motor mount and fixed it "under warranty" Funny how I drove in with 102k miles but on the paper it said 92k. That fixed the vibrations.
Now they are saying that the left side CV joint is bad, too. They are going to replace it and see if the problem goes away.
I'm losing faith in these people. It seems all they know how to do is blame CV joints and take a shot in the dark.
I'll know more by the end of the day today.
Let us know rob. I know i had it and mine turned out to be the motor mount. I mainly felt it under acceleration.Once cruising it went away till i put more throttle into it. It may be a bad CV, usually a shop should be able to see once up on the lift though.
Something, something, yes
I've experienced similar problems with my 03 TL-S as well. I've had a cracked motor mount at least once since I've had the car, which sucks, but luckily it was covered under my extended warranty.
Do you ever notice a vibration problem with braking? I get that issue at times too. They've machined my rotors because they were warped. They did this a few months ago and it's starting again... needless to say I'm not going to pay them to fix it again. My Acura shop in KC is really good about fixing their flubs, but it sucks to have anyone screw up even once.
Anyone have any thoughts on something other than the rotors that's causing my vibrations when braking?
S E L L
Originally Posted by FINDLAYACURA
SORRY I GAVE THE WRONG EMAIL ADDRESS ITS CHOWELL@FINDLAYAUTO.COM
I WORK FOR ACURA AND I CAN TELL YOU ON THIS TL IT IS VERY COMMON TO HAVE THIS PROBLEM WITH THE FRONT MOTOR MOUNT OUT AND THE PASSENGER SIDE MOTOR MOUNT AS WELL RECCOMEND YOU CHECK AND REPLACE BOTH OF THESE ITEMS YOU CAN CONTACT ME AT CHOWELL@FINDLAYACURA.COM AND ILL HOOK YOU UP ON PRICE AND SHIPPING OF OEM MOUNTS.
CLINT HOWELL
PARTS MANAGER
FINDLAY ACURA
HENDERSON NV
702-982-4160
CLINT HOWELL
PARTS MANAGER
FINDLAY ACURA
HENDERSON NV
702-982-4160
I just picked up the car.
Most of the vibrations and shaking are gone after replacing both CV joints. However, I still feel slight vibrations under acceleration and sometimes while cruising. It might just be the tires or an engine mount(s).
But yeah, most of it are gone. *sigh*
Try replacing the front or looking at it closer. Mine went away with the replacement of that. Also inspect the side for cracks.
Guess the Genesis is looking better and better to you huh rob
When are you coming down for a tour, Kris?
Haha. Well, I still love my TL and when the time comes, it's going to be very difficult to part ways with it. But yes, problems like this would make the transition a bit easier for me emotionally.
The door is always open for you.
It was hard for me to part with my TL ... but I sold it to a guy I went to grade school with and he's a mechanic, so I know the TL (aka 'Inspire') is in good hands.
Oh ... sure, invite Kris but no one else on this board, huh? I know where I'm not wanted!
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Originally Posted by derrick
Hey Rob,
With how hot it is in Detroit today and forecasted this weekend, I'll wait until closer to winter to visit 'bama.
Ha, get the car out of the shop on Friday, have another problem on Monday.
I hit road debris on I-65 in the construction zone this morning and it took a chunk out of the sidewall in the front left tire (the sidewall belts are showing) and it severely bent and scratched my BBS wheel.
I am not too happy right now.
Derrick - my invitation to Kris was based on a previous conversation via PM.
You're also always welcome down here. You know that!
