jacking points
Old Dec 18, 2004 | 03:00 PM
shogun's Avatar
im the best
jacking points
anyone have any pics of the jack point in the front and rear? most of the older threads have lost them :[
anyways there looks to be some black hump dead in the middle of the front just beyond the plastic scrapeguard thing is that usable?
Old Dec 18, 2004 | 05:20 PM
shawn744's Avatar
Kollage is funn!
there should be little arrows on the side skirt marking the jack point......dunno about you guys but my front jack point got bent in....now they're flat....
Old Dec 18, 2004 | 06:15 PM
fsttyms1's Avatar
they are the only tabs about 4 inches long sticking down on the rocker panel
Old Dec 18, 2004 | 11:09 PM
asloudasitgets's Avatar
yea like the previous post say if you crawl down and look under there are 3 inch tabs that fit right over the grrove of your stock jack.
but since my front stock lift points were bent i use the frame to lift with my floor jack.
just make sure you are lifting from a soild piece of the car and no suspension pieces, of course you know this but just in case. I had no clue also other than using the stock lift points where to lift the car from, but once you go under your car and start tapping against some pieces that look sturdy and sound soild then your good to go in using a floor jack.
Old Dec 19, 2004 | 10:16 AM
shogun's Avatar
im the best
im not talking about the side points but the front and rear where you can lift the entire front and rear sections so you can put jack stands under the mentioned 'arrowed' spots. i already know about the 4 arrowed points but there are some other locations you can use so that you can utilize jack stands. ive heard you can use spots near(?) the tow points and there should be a spot in the center of the car, front and rear, but i dont know what they are
Old Dec 19, 2004 | 10:21 AM
fsttyms1's Avatar
dead center in the front of the car just past the radiator there is one. the 2 (one on each side) tow hooks can also be used to lift the car. the rear some have used the rear tow hook/loop to lift also. id take pics but i lent my parents my digital camera
Old Dec 19, 2004 | 10:56 AM
shogun's Avatar
im the best
is there a 'bumped' piece of metal beyond the radiator/plastic scrape guard? i was looking at it and it seemed like one but i tried to use it and it creaked after a few jacks so i decided to pass and await further (your) reply
it seems like that point is pretty far forward in front of the front wheels but it looks to be the only spot that might be useable.
Mike734
Dec 10, 2021 01:25 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
