iPod/MP3-player support in 2003 TL
#41
Originally Posted by Trackruner228
thanks for the info i guess its not really worth the upgrade since I dont have a navi. What im curious about is the website says this will let you change tracks with the wheel controls that would be the big seller for me but im a little skeptical about that.
#42
Originally Posted by AcuraBuddy
Yes it does, the USASPEC and I believe the PIE also can control the IPOD straight from the steering wheel and also on the unit itself and their is also an option by flicking the switch on the box to either control the playlist from your head unit or you can control it from your ipod direct. I would highly recommend the USASPEC and you can read some reviews on Crutchfield and if you have any questions or doubt you can give the dude at Enfig a call. They are very friendly
#43
I've tried a few FM transmitters in addition to the built in FM transmitter on the actual XM receiver unit. They are faint and don't deliver lound sound. I can get it static free though. The tape unit is much much better, but since it's a moving part, it makes clicking noises and I just don't like the fact that I'm using a tape. Also, the tape deck seems to "wind" up w/ the RPM's of the car. Sounds like a mini-supercharger. While funny, it's rather annoying.
I'll be ordering a Blitzsafe tomorrow. The place I found was ~$89. Not nearly the $70 I thought it was going to be from reading other posts. But eh.
#44
try ebay or enfigcarstereo before you pay 89 bux for it. I might suggest the USASPEC one if you are going to spend 89 dollars its only like 20 dollars more for all those capabilities. Dont rush to fast into cuz you can get better then a blitzsafe.
#45
Ok I went to the website and researched both of them for my car I seemed to like the Ipod2car better but I noticed it said you can control it using the steering wheel contorls? That would be really nice if its true because I hate that about the cheap tape thing I have now. So I was just wondering if anyone can confirm that it really does work?
I understand that the I-HONDA-R2 is supposed to do the same thing but what is supposed to be they dont say how it works? I just get they both do the same thing so why would I pay more for 1? Anyone know about this either? Any information at all would be very appericated?
I'll have to send both back, I'm thinking of trying a new one. The USASpec one seems interesting. Any good experiences with this unit on a non-navi 2003 TL?
#47
Like I said, so far I ve had a nice time with the USASPEC, as it was also recommended to me by those guys there at enfig haha maybe cuz it was the most priciest one but heck I'll take their word for it that they use it on their cars and that it is very good unit. I personally use it as of this past weekend and so far I love it. so its a two thumbs up from me
#48
Originally Posted by jpadilla
are you still having issues with the Dice?
It stops working all the time, makes the radio-unit ask for the code suddenly and sometimes makes the radio stop working all together. I removed the Dice unit all together and the radio works fine again...
#49
i think i'm gonna ordering the USA SPEC PA11-HOD from Crutchfield
http://www.crutchfield.com/S-WFqzF11...1HON&s=0&cc=01
#51
Anybody know how the USA Spec and Blitz, etc. compare to the HK Drive and Play? I've got one ready to install, but if these others are better/easier, I'm taking it back. How do the steering wheel controls work with the HK, and is the little controller supposed to take that job? Yes, I am a moron when it comes to this stuff.
#52
where did you install the module at? I was thinking under the passenger's seat with the dip switches facing the rear so i can easily reach under to flip them between play list mode and direct access mode.
#53
Yup I put mine underneath the passenger side seat because thats probably one of the only places you can hide everything . well you should of checked ebay or enfigcarstereo but thats ok if the peace of mind of being able to return something makes you feel better thats all good.
#54
I need some help with mine. I removed the wood trim and then unscrewed the side panel screws and then removed that little peice that snaps in however once there the panel doesnt watn to seem to come out how does it come out i dont want to break it in half? Also im supposed to be on the right side correct?
#56
Ok all you need to do is open the passenger side panel. You ll need to unscrew the center console and pull it back alittle bit and then you take off the wooden piece and then u unscrew that side passenger panel and pull that out and after that you will have a very small opening to put your to fingers in to pluck in the 14 pin slot . Does that answer your question? Plus you dont need to open the driver side panel at all cuz you wont be getting that one out easily or at all.
#57
#58
http://www.skyeflye.com/acura_cls/In...01-2003_CL.pdf
#59
my usaspec come in tommorrow ... now i'll need upgrade my ipod mini .... 30gig video or 8gig nano? I dont care about the video or pictures, i just want the space but heard battery an issue on the 30gig.
#60
Oh ok thanks see pulling back the center consule after you remove it makes sense because the side panel on the right wouldnt move out and I thought huh but the reason was because the other panel closer to the center consule was blocking it. Once I do this im diffenently making a small DIY for it so other people wont get confused like I did. Thanks for all your help.
No problem dude anytime. For the guy thats buying the 8gb Nano or the video well I might say the video because it seems like its more worth it even though I have the 8gb Nano
#61
Installed the USA SPEC .... works perfectly! HU and stearing wheel controlls work, can select up to 5 different playlist using the CD buttons, CD6 is play all! even has an aux input. Glad I chose the USA SPEC! Thanks!
#62
dont forget you can flip the switch off and use your ipod to control the playlist instead of the 5 playlists and you can still control from the steering wheel and from the head unit. I flipped it off so I can do that and plus the song switching is faster.
#63
Ok, I've just ordered the USA Spec PA11-HON from enfig for my Acura 2003 3.2TL (non-navigation, facotry stereo). Hopefully this will work better than the Dice unit...
#65
Originally Posted by DUECE_DXJ
will it work if you have navi? if so what parts do I need?
#66
Sorry to revive this thread, but you should be glad I searched
Anyways, I'm pretty much sold on the USA-SPEC, I just need to know for sure if it will work on a 2003 Acura TL Type-S non-navi, with a 6 disk in-dash cd changer....
#67
#68
Call a retailer and ask them. I'm using the USA-SPEC on a 2000 TL. It was about a 15-20 minute install. I did not pull the entire console apart. Just the kick guard and glove box.
With my fingers I popped the connector into my stereo and feed the cables into the glove box. It's been working very well for the last month, maybe two now.
#69
#70
Thats an interesting way to do it. How hard is it though to reach over and get it? I have mine through the center console and while I like it there is a lot of cord that sits in there.
#71
Well of the 15-20 minutes, most of the time was spent getting it in. At one point I thought I wasn't getting it and then I tried it again. Pop it was in.
#72
No, what I mean is when your driving and you relieze you want your Ipod is it annoying to have it all the way over in the glove box?
#73
Their comment about there not being any available input is contrary to some of the things I've read here, and I can go ahead and check for myself -- but before I do that, if anyone can confirm/deny that for me, I'd appreciate it. And if someone could further confirm whether the USA-SPEC unit in particular will work with a 2003 TL stock HU with 6-CD changer in-dash, I'd very much appreciate that as well.
Also, if there's some better option as of 2011 that someone can share, I'd like to hear about it.
#74
Sorry for reviving this thread yet again, 3 years later - but I've searched the whole site and haven't found an answer to this question anywhere. I just called Crutchfield and they told me that the USA-SPEC (and every other integration option) requires a changer input and that the Acura stock HU with the in-dash changer doesn't have that (or any other available) input. And that therefore there was NO option available other than an old-school tape adapter stuck into the cassette player with wires everywhere.
From what I understand, some head units have the changer plugin in the back *and* an internal changer, and some don't... seems to be luck of the draw..
can anybody correct me if I'm wrong?
Pham Alvan
03-16-2016 09:17 AM
ExcelerateRep
10-14-2015 08:20 AM
