Interior driver side door handle broke :(
5 minutes... DIY
1. O - Using a small flat head screw driver, pry off the plastic cover. Then remove the philips screw.
2. Slide handle forward/outward until loose and have some clearance to remove linkage.
3. X - Unhook door handle rod by pivoting plastic clip from top/above.
4. Release wire connectors for power lock and seat memory.
Install in reverse order.
If you break the plastic cover tab you can glue/hold it in place with dum dum or equivalent; rubber cement. .. etc. Long as it covers the screw. Can also replace with new but need to match color.
Seriously, its that easy. Remove the little cap the covers the screw. Remove the screw, slide the whole assembly like the arrow shows, pull out enough to get to the little clip that holds the rod to the handle, pop clip off of rod pull rod out of handle, unplug wiring. Reverse for install.
It's easy. One little plastic cap that covers a philips screw. Just pop off the cap using a flat head screw driver. Then remove the philips screw. Then the whole assembly is loose and can be slid out a little bit to allow removing one clip. Then slide out some more. Then unplug the wire going to the seat controls. Then slide the assembly the rest of the way off.
rockyboy
08-04-2024 10:35 AM
tman570
06-11-2019 07:56 AM
sockr1
10-01-2015 01:31 AM
