intake spacer mod
intake spacer mod
i will make a diy on what u need and what to do, but for now this is what im doing.
what i started with
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/spacer%20mod/2009-10-14121502.jpg)
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/spacer%20mod/2009-10-14121532.jpg)
what i have done so far.
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/spacer%20mod/2009-10-14143519.jpg)
only for looks, like the cleaner look with no tabs. still got to add a few more goodies to it and it will be ready to get installed.
what i started with
Sweet.
I wish i had room for this mod under my hood. I am also planing on doing the 09 Intake manifold.
im gonna let a friend try it out on his 01 with cl-s engine and 6spd swap to see how much room he has. i know the engine sits higher but u might get away it cutting the bar and putting spacer under the hood hinges. also u can mill it down a bit.
I have about 1/4 inch. I would have to cut the hood and power bulge it.
Traded in my
Just to clarify:
Clearance is an issue even in Type-S or just '99-'01 TL-P?
For Kris:
'09 manifold will fit Type-S or just the TL-P with the smaller TB?
Very interested in this thread and awaiting results.
For Kris:
clearance is an issue.
read ur choices above on what to do.
kris can put it on bc he has a type s engine in his 99-01. with the oem engine in the 99-01 u will have the same problem as the rest of us.
09 manifold will fit type s and i want to say the tl-p but no one has done it on a tl-p/cl-p.
^ the 09 should fit the tl-p as well since the type-s manifold bolts right up to the 00-03 (99 is a little different)
