Intake resonator
Nope. It is just a separate box below the air cleaner box. The air cleaner box holds the air filter. Some folks choose to change to a high-performance, or hi-flow, filter, but it's not a requirement.
make sure you grab the small plastic piece that tries to stay behind
When finished there will be 2 large open holes on the bottem of air filter box where the res box used to attach
Now there is air direct feed from the large area of inner wheel well- plus that area has drain holes on bottem plastic cover so not an issue from water that way
and being up high prevents water in like CAI systems get
a high flow filter will pay you back, and makes TL sound and run like a V8 motor above 4700 rpm
It also goes from sipping to gulping mode on the fuel in vtec so be aware that fun cost
as with most things TL- when I get specific of course that item will vary by year DOH!
drill another hole!!
qty:2, 3 or 4 inch diameter holes will allow the engine to suck in as much air as it wants at any time
Any suggestions, guys?
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
