Installing wood AC trim
It's real easy dude, just clean the area real good with some rubbing alcohol, make sure its clean though no armoral or anything, then peel the little plastic tabs of the tape strips on the back of the wood trim and just stick it on, it fits real tight to the edges so it isnt hard to match it up perfect. Then take a hair dryer and heat the wood pieces and press it down hard, and your all done. Also hold the pieces up to make sure they fit right before you start anything, good luck
![Cheers](https://acurazine.com/forums/images/smilies/cheers.gif)
Just for clarification, do I have to remove any of the existing "standard" AC trim? If so, do I just pry it off with a knife?
Please forgive any ignorance. I really just getting into this, but it's my wife's car, and I really don't want to screw it up.
09-17-2015 09:01 PM
