Installing new battery... Tips?
I've done some searches, and determined that a Red-top Optima will do fine for me.
What I wasen't able to figure out though, is once I get my radio code, what do I do to reprogram the radio??
Also where would I get the appropriate tie-downs and cover for the battery being that the stock one's apparently dont fit.
Thanks for the help...
You can remove the battery cover and bottom part then just ask Optima to send u a peice that you can either put on top or on the bottom of the battery to raise it to the correct height. They will send it for free. Once raised you will be able to use the stock tie-down
When the stock headunit says CODE then just punch in the code 1-6 for 5 digits i believe for example
54321, just hit 5 then 4 then 3 then 2 then 1
I don't understand I put an optima yellow top in my car about 2 weeks ago and other than not fitting the box 100% I had no problem with tie down, oh, btw I have the Comptech billet tie down with the stock rods and imho the battery looks better without the top cover
Jeff
Jeff
I took out that box and it looks better. The yellowtop was a little too low for the stock connectors to reach for a tight fit. Pepboys didnt have the spacer for me so Optima sent one to me in 2 or 3 days.
okay, if i hav a high-drain stereo plus blue LEDs in my headlights and taillights that blink all night long when my alarm is armed with autostart and pager alarm, auto window/sunroof open/close, etc, which is recommended? red or yellow? thanx ahead
actually it does matter, the car has a total of 8 blinking LEDs (including the stock LEDs) all night long and if i dont drive it for about 24-30 hours it usually needs a jump to start it up so thats why i been thinkin bout a better battery. LOL running the stereo without the car running only lasts about 5 minutes before the battery dies!
Otherwise the yellow top works fine for me. I can have the radio playing for hours but I think the red top would of done the same. I dont have crazy stuff in the car.
either will work. ive never had a issue with large stereos with the red top in the past. (i even left my 85 watt piaa fogs on all night once and was able to start the truck up in the am with out a problem) 1 more thing to consider is what climate your in, (you wont have a problem) but cold climates may opt for teh red top just due to the larger CCA
Yes - that measurement has only to do with starting. As far as the difference between the yellow and red top, the yellow top is more expensive. It's a deep cycle battery, which - unless you're familiar with trolling motors for fishing boats (or some other similar high drain application) probably doesn't mean much to you.
A deep cycle battery (like a yellow top) can handle repeated discharges better than a standard battery. The normal lead-acid battery is not designed to be discharged. It can actually hurt it and shorten its life if you discharge it.
Yellow tops are recommended where you will have circumstances where you are running a car stereo without the car on, or other low charge situations (perhaps a car with underdrive pulleys and a high wattage system). They are more forgiving and long-lasting in those situations.
Originally Posted by Soundscape Studios
Okay Bxscig and all, thanks for the info. But I just want to make sure - by "stock head unit" you mean the radio, right?
Originally Posted by optomos
If you have a high power audio system get the yellowtop. The redtop wasnt made for that application. It will just kill it.
i had a red top for 6 years (still running fine) with a 2500 watt stereo and it never hurt it.
The term "deep cycle" comes from the fact they go from topped off, to a deep cycle drain down to about 5-7 VDC, and will recover on the next recharge. Standard car batteries or starter batteries as they are known do not recover from this very well.
the yellow top battery as was said before cost more and is considered a dual purpose battery... deep cycle and starter. It is heavier than the red-top battery to pick up and the reason for that is that it contains more lead ... which in the end allows it to hold more total power or Henrys of energy if i remember the terms correctly.
you can look at electricity like water in a hose... volts are how much pressure is on the water, amps (as in CCA) is a measure of the amount of water that is flowing and watts are the measure of amount of electricity that flows for at a certain time. you could up the pressure... volts.. and leave the amps the same and get more wattage or vive versa since volts X amps = watts.
now that the different terms are hopefully more clear it should be said that the two batteries are each better in their own ways. Because of the make of the red top it can offer more CCA (cold cranking amps). Over the long run it will run out of power if not recharged faster than the yellow top and will not recover from the discharge as well. If you live in a very cold place it takes more juice to turn things over on a cold day howeever and the CCA may be what you are looking for. (honestly we only have a medium sized six cylinder and either should be plenty). The yellow top offers dual functionality, meaning it is both a starter and a dual cycle battery, which means it will handle long parked sessions better with the radio playing and you and your wife/girlfriend making out. It cost more however....
To each their own. i would get the red top if you are determined to get one or the other but the warranty is only 3 years and the batteries cost a lot more than a regular one. Optima claims that their batteries last 2 times as long as a normal battery and then put half the warranty on them that you can get on a standard battery. I am seriously contimplating just getting a regular battery and saving the money as I dont see it would make much difference in the end.
i have one in teh TL now for over a year and expect it to last well into my next car forsure. teh red top is well worth the $$ considering the oem battery only lasted 3 1/2 years or so for me
see and recommendations like that are why i will end up spending the extra $45 or so dollars on the red top... thanks a lot fsttyms1!!! *smiles*
thanx guys! sorry soundscape for
ing ur thread
yeah we do it-I MEAN make out-with the car runnin anyway
now all i need is to find out how much each battery would cost
haha, gman reminded me of my electronics teacher back in high school with that waterhose theory
seriously though guys thanx a lot
any clues on prices?
ing ur thread
Just called my local Advance Auto Parts and here is what I found....
Autocraft silver - 2yr warranty - 585 CCA - $49.94
Autocraft Titanium - 3 yr warranty - 700 CCA - $64.94
Optima Red Top - 3 yr warranty - 800 CCA - $109.88
Optima Yellow Top - (forgot to ask warranty) - 750 CCA - $159.88
Originally Posted by yunginTL
which model # for the yellow top for our application?
Originally Posted by MikePA
now its actually to the point where if i play my stereo for a few minutes with it off, i gotta jump start it.
, but what's CCA again?
