Installing LED Flashers in the headlights
Hey guys,
Im about to install the LED Flashers to blink when alarm is armed, and stay on when the parking lights on. Now, I also want to add a switch, so I can turn them off completely, the switch has three inputs, Ground, Load, and Power....Im slighty confused with LOAD input....the hot wire should be connected to power or to load?
thanx in advance for yer help
yes, i forgot to mention that one, so the hot wire to the LOAD, and then just 12v to power the lighted switch? can same hot wire be on both?
or if i dont want it to light up, i just dont connect the power?
Registered User
i dont see a problem with having the hot wire on both.. but if u dont want it to light up then u dont have to connect it.. you will still get power.. just no light
ok, thanx for the info
alright, back to the garage.
only when the alarm armed they will be blinking,
with parking lights on, they will be steady on.
lol, even with steady on, im sure they will be busting my chops, especially in SI, thats why I wantted the switch...
speaking of PBA, I just got my 2005 PBAs
im not talking about factory alarm, well, you can still do it, you can make the LEDs blink when the car is off, and stay on, when the parking lights are on...same concept. Flashers have 4 wires, red to battery, black to ground, blue to headlights/parking lights, and yellow to a hot 12 wire that is off when the car is off.
Well, I just finished doing mine, I must say it looks awesome, a bit too bright, but nice. I assume it will not drain my battery too much. I believe it was 15 units of power.
Power: 50mA / 25mA (constant / flashing) is this a lot of consumption for flashing 25mA?
i'll do my best, but now its raining, maybe tomorrow
pts for yous.
pts for yous.
I installed the flasher in the high-beam area, so when they are one, the fill up the high-beam area which looks pretty nice.
I also realized that I dont really need the switch, I thought that I may need it to turn off the flashers if they were catching attention from the cops. I pointed the flasher towards the reflective wall of the high-beams area. As it turns out, when the headlights are on, and the flashers are on at the same time, the flasher are almost invisible. They only fill up high-beam area when the headlights are off, which is what I need.
I will try to take a little video tomorrow.
here is the video, the quality is OK. The flashers look better in person.
http://www.angelfire.com/linux/teknoking/MVI_0134.AVI
I will try to find a faster host.
thanx, by strobes you mean those crazy bright and fast white flashing?
thank you
hey guys, I just got 2 Blue LED Scanners, 12v each. It says to use a fuse for safety, what fuse do I use?
Originally Posted by Blazin_TL
i have one of thoes behind my rear view mirror.. i didnt use a fuse, but if u do u can get a inline fuse holder with about 20 amps
if is a varad one get a 5 amp fuse
Future JDM Whore
copy and paste the link in ur url box.............tekno the lights look HOT i had bought the headlight led's from street glow a while back and when i went to install them i was old drilling the hole in the housing can crack it......did u have any problems with it??.....lol im pissed cuz i sold the lights to my boy
RLX-Sport Hybrid
3G RLX (2013+)
43
12-16-2015 10:45 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
