Install Comptech Exhaust
Old Jan 3, 2002 | 10:19 AM
myrolex's Avatar
DOES ANYBODY HAVE EXPERIENCE WITH INSTALLING A COMPTECH AXEL BACK EXHAUST ON A 2002 TLS, IF SO THEN DOES COMPTECH PROVIDE EVERYTHING NEEDED (GASKET'S ETC...) AND CAN YOU GIVE ANY ADVICE WHEN INSTALLING THIS.
Old Jan 3, 2002 | 10:30 AM
badazzTL's Avatar
Peach Tea
does anyone have that CAPS LOCK pic??
Old Jan 3, 2002 | 10:52 AM
TypeSDragon's Avatar
Loving my 08 TLS!
I bought an used comptech exhaust and all it came with was the 4 screws. It is not hard at all installing. Make sure you have at least one wratchet to work with and lots of WD40. The screws are tight as hell. Remove the two screws from connection points of the Y pipe and you should be able to lift up the hangers. Took me an 1 1/2 hr because it was cold and I took my time. Oh one more thing, after you put on the exhaust, they may not look even. I used some zip tights to make them look even. If you have any questions, let me know.
You can see the left muffler is hanging lower. This is a old pic, now it is even because I used the zip tights to pull it up.
Old Jan 3, 2002 | 11:01 AM
daverman's Avatar
You mean this one?
Old Jan 3, 2002 | 12:01 PM
juniorbean's Avatar
Lightbulb
he he.. funny CAPS lock pic!!
mine was brand new and came with the same stuff that TypeSDragon's did, so that's what they all come with. It took me about 1/2 an hour to do. It was very easy. Hardest part was getting the old exhaust off b/c the bolts were so damn tight. That alone took me 15-20 min. I have zero mechanic hands-on knowledge other then changing oil and I did the exhaust in 1/2 hour.... so that means anyone should be able to do it. Good luck
Old Jan 3, 2002 | 02:16 PM
badazzTL's Avatar
Peach Tea
Originally posted by daverman
You mean this one?
LOL yeah thats the one
Old Jan 3, 2002 | 09:56 PM
Guest
Guest
Posts: n/a
Total newbie question, but what does the Comptech Exhaust do for your car? It is strictly for esthetics?
Sorry for the stupid question!
Mikeb
Old Jan 3, 2002 | 10:12 PM
Loving my 08 TLS!
The exhaust is only for looks and sound. Maybe a 2-3 hp gain max.
Mikeb
Old Jan 3, 2002 | 10:25 PM
ElegantTL-S's Avatar
¤ Club Inspire ¤
sound? what sound? hahah! :p if you want sound..you gotta get a fartcan.... j/k!!
Old Jan 3, 2002 | 11:08 PM
Wash n Wax's Avatar
Originally posted by TypeSDragon
You can see the left is hanging lower.
It seems like whenever you have two of something, ones hangs lower.
Old Jan 4, 2002 | 10:53 AM
badazzTL's Avatar
Peach Tea
Old Jan 4, 2002 | 03:11 PM
jhalderman's Avatar
When I installed my Comptech exhaust the right side did hang lower than the right but it was very easy to fix without using zip ties. I simply loosen the attaching bolts and had a helper hold the muffler up while I retighten the bolts and it worked great-nice and level now. I hope this helps.
Old Jan 4, 2002 | 06:45 PM
Road Rage's Avatar
Not a Blowhole
The shop manual shows gaskets, but there are none required - it is a press fit and the tolerances are such that no leakage has occured in the 3 I have done.
Removing the stock bolts is tight, as they are a locking type nut. I personally did not like the droning boom sound inside the car, and sold them to one of the posters oin this thread (anonynmity retained).
Old Jan 4, 2002 | 11:45 PM
typeSmaximum's Avatar
Anyone else with droning boom? I get mine with headers end of this month.
Old Feb 20, 2002 | 02:05 AM
my2sense's Avatar
f-a-b-o-l-o-u-s
this may be a stupid question - but where does one purchase zip ties?
Old Feb 20, 2002 | 03:35 AM
asiankidd's Avatar
anywhere!!!!! hope that helps hehehe
Old Feb 20, 2002 | 07:46 AM
Loving my 08 TLS!
Any hardware store should have it! Home Depot!!!
Old Feb 20, 2002 | 01:57 PM
I'm with RR on this one, too much cabin noise for me. Don't know how the quiet tips affect that.
If I wasn't concerned with noise I'd be tempted to install flow masters again, after hearing that sound clip someone posted last week...
I wish the tips had a centering piece in them like the stock ones and I'd buy those instead of a cheap bolt (that most people have stripped) that pushes from one side...
Old Feb 20, 2002 | 02:44 PM
Austin519's Avatar
myrolex:
What you gotta do to get the screws off...either get a 2 ft long metal tube or another wrench, and put the tube over the wrench for a larger leverage arm, or hook one wrench into the other...took me about 10 minutes to install once I tried that. Did it at 9PM in a parking lot at an Acura meet You can check out pics if you want at the website in my sig...
Austin519
Old Feb 20, 2002 | 07:18 PM
jnltf24's Avatar
When I installed my exhaust, it was 40 degrees outside - didn't want to spend more time than I needed. Getting the screws off was really tough. I called a mechanic friend I know and asked his advice. He told me to use a torch! WTF is that, I'm no mechanic and have no torch. Then I realized I have a cooking torch (for creme brulee for all you chefs ) Sprayed some lubricant on the screws and torched it up for a couple minutes. Screws came off like that. Butter! I was pretty impressed with that technique as well as my ability not to start a fire. Good luck!
BoricuaTL
Apr 8, 2016 01:08 PM
IIDXholic
Oct 8, 2015 07:53 AM
k6biv
Sep 22, 2015 02:06 PM
k6biv
Sep 10, 2015 06:37 PM
