Injen vs Aem
Injen vs Aem
i saw a thread on this cant seem to find it but anyways, i have been doing research and Injen is so much more expensive than Aem.. Anybody know why? is one better than the other? Also i've notice that Injen has the color black where Aem only has blue, red,silver , and polished.. I would like to find an Aem black... anybody knows where i can find that it would help.. thanks...
Purchased: April 28, 2001
HOWEVER...since further reports of AEM's mounting bracket failure is starting to get more popular, people are starting to look at alternatives. Maybe that's why Injen is starting to get more expensive...since by now I'm pretty sure Injen prooved its long term durability & quality over the AEM.
All I know is that EVEN *IF Injen was "better"...if you live in CA, I still suggest buying AEM simply because they have a CARB sticker. It's too late for me since I didn't know any better when I made my purchase...now I have to find a shop that'll pass me on the visual inspection. (Then again even *IF I had the AEM, I still would have to worry about passing with the non-CARB OBX headers).
im in VA dont know if it will be a problem...
Only Californians have to worry about CARB stickers...you'll be fine with whatever you choose.
Drivin' it till it dies!!
Does anyone know if an air bypass valve could be used with the Injen CAI? That's the only thing stopping me from buying the Injen. I just want to be sure that if the filter takes on water, it will be displaced before it enters my throttle body.
Good luck with the by-pass. It may look good on paper...but put in practical daily use...it does TONS more damage than benefits. I would stay CLEAR of the bypass regardless of intake I use.
P.S. The bypass doesn't care what pipe you put it on...as long as you get the right size of pipe (TLS=3 inches) & match it with the right bypass size, it'll fit no matter what.
where did you get those mesh grill? and who cleans ur engine?
I think buy reading this thread I'm also in the market for an Injen CAI (maybe red?). Thanks guys.
What do you mean by doing more damage. Does the by-pass let in dirt particles? That is the only problem I see.
Check the store on this site. They sell the Injen in black.
Does anybody know why the 2-piece Injen cannot be used in the type-s? I would like to change back and forth between short ram and CAI, that's why I'm asking.
I'm really sorry for the , really.
Originally Posted by BiggJ12
check out the AEM V2 intake!!! check the DYNO tests! it rules over the injen
Aem V2
go to www.aempower.com and check out the V2 information. also check out the DYNO tests! the V2 is far more sophisticated than a regular CAI and performs awesome with a VTEC engine!!
#1 The by-pass lets dirt in. A REAL foam filter is oiled and doesn't dry up...whereas the foam filter included in the bi-pass will dry up and eventually be eaten away by the elements. If a filter is dry (this is the same with cotton) it does not filter properly any more. In addition...YOUR ENGINE will start sucking in brittle foam.
#2 After extended use, the valves *may break off and be lodged INSIDE your throttle body. This can be caused by over exposure to the elements and by the constant vibration the pipe goes through causing the entire casting to crack and cave in.
#3 The valves NEVER fully close...it is ALWAYS letting hot air in reducing performance (even IF the foam filter worked properly).
#4 The change in pipe diameter causes turbulence in the overall design of the intake, reducing the effectiveness of the CAI even further. Hypothetically...if the valves never break and close 100%...and the foam filter is the best filter on earth which means it never dries up...by design alone the by-pass STILL robs power by creating turbulence. THIS IS A KNOWN FACT THAT EVEN AEM ADMITS TO.
Items #1-3 IS CONFIRMED by trusted members between ATL & ACL who all had bypass filters. If...you are still convinced and want to use the bypass...at the VERY MINIMUM don't buy it new...there are TONS of bypass owners that is willing to sell (or even give it away) their existing one.
whoa - relax.
It's not really a valve.
Take a straw, suck on it.
Now cut (or bite) a hole in the straw halfway up it
Suck again. See if the air is coming from the bottom or the new cut out.
While sucking, emerse the straw in water. You will now be sucking air from the cutout, not the end.
If the end is not blocked (or under water), the air comes from there, not the cutout (or bypass "valve").
the aem V2 intake is non type S... is there one for the Type S?
Originally Posted by orion_21
whoa - relax.
I suggest you do more homework. Like I said...it only looks "good" on paper.
Anybody? I'd like to know also if there is one for the type-s.
Go here...
www.aempower.com
If you still don't believe that there is NO V2 for the Type-S...call them here.
AEM Headquarters
Also...refer to the FAQ regarding the "Bypass Valve"
Q: Can I use an AEM Bypass Valve with the V2?
A: AEM V2 Intake Air Induction Systems utilize a dual chamber to create multiple frequency sound waves. The installation of the AEM Bypass Valve would disrupt the tuning of these systems. Therefore the bypass valve should not be used.
Q: Will the AEM Bypass Valve cause a loss of power?
A: The bypass valve may cause a slight loss in power due to the interrupted wall section created by the internal shape of the valve...
Kollage is funn!
1 Post
pistacio- there isn't one for the Type S....i've researched this. i'm getting the INJEN race division CAI....i from what i see and hear so far i recommend it....however my install date for my intake is tomorrow (7/12/04)....
one more thing....hey pistacio, what's with your tint on the windows?? your ride looks so sick, i just think it needs some tints....on ABP, i'd put a good 20% or 25%. what do ya think?
The Injen RD , is that a one piece or two?
