Ingall's Stiffy ETD mount
just want to let you all now that, Ingalls might be using my car, to be able to make a direct bolt-in of their stiffy mount for our cars
so it might help solve some of those motor mount issues, especially the side ones
http://www.ingallseng.com/93051-stif...accord-v6.html
link is for the newer accords though
2g CL's thread link:
https://acurazine.com/forums/showthr...0#post11659950
Where is this going to mount? Up high or lower by the mounts?
-Arsenic-
wham bam thank you ma'am
they should make mounts for the auto guys like we have in our 6spds. two dampers by the mounts (front and rear) that will improve wheel hop and make the mounts last a long time.
mounting it up high is ehhhhhhhh, it will do some of the work but wheel hop will still kill the mounts
Yeah the dealer wanted to charge me like 260 for 2 mounts. I was having the tranny replaced and they found two broken mounts. Even if its around that price i'll prob get one.
yes, i did pick it up , had to figure out a couple of things first, with the design (mainly if they can get the low side A/C port still accesible for service with out removing the mount (it clears no issue, you just can't get a coupler on it currently), then also try and clear up the instructions a little bit better, with more pictures and such
as far as pictures, heres a teaser
i am not going to actually put one out , till it is actually out, which is actually suppose (will happen probably, but stuff does come up though unforseen)to be around the end of the month
as far as it working loving it, and it seriously knocks down that engine movement with only stock mounts otherwise; increased noise, a little bit, but nothing bad though, but i do have it almost maxed out though , but you if you want stock noise levels, you be better off staying with ONLY the stock mounts
as far as stiffer bushings for it, i did ask about them, but not currently in the process though
