ignition coils w? fuel pump replacement
My engine started knocking upon start and acceleration (2001 type s) Check engine light came on and flashed. Mechanic changed the fuel pump because it was going at a high psi and that took care of the check engine light. He said to replace the spark plugs and coil packs because they were soaked in gas. Does a bad fuel pump cause this? Any feedback would be appreciated. . .Thank you
