Ignition Coil
Old Aug 19, 2004 | 08:11 AM
Ignition Coil
How much does it cost in the dealer? And any other places that sell it? I think 1 of them is misfiring.
Old Aug 19, 2004 | 09:14 AM
Daggra105's Avatar
i had a misfire on a BMW. OBD II showed piston number 5. the BMW drove like it had a bad fuel pump. total cost of repair $160.
its a DIY. the part should cost around $50 and about an hour to switch it out. just make sure you know which one is bad....
Old Aug 19, 2004 | 09:21 AM
So it's $50 for acura oem part or aftermarket? I check the computer and it said cylinder 1 misfire, so I know which one.
Old Aug 19, 2004 | 11:12 AM
NSXNEXT's Avatar
If it takes you more than 5 minutes to switch it out, you are incompetent. And yes, they are about $50 a piece through the dealer. If it's the coils in the front, they are very easy. The ones in back are a little harder to get to, but still pretty easy to replace. You need an allen wrench to get them off.
Make sure it's not the spark plug before you go spend any money on coil packs.
Old Aug 19, 2004 | 03:17 PM
Engine light was on. Had it checked, cyIinder 1 mifire. reseted the computer and changed all the plugs and the engine light came back on. had a diagnostic, came back misfire cylinder 1. I took the coil out and wrapped electric tap around the boot area. it didn't help. now i'm thinking of changing it.
unless i was wrong with which cylinder being number 1. is cylinder 1 the one in the back and left?
Old Aug 19, 2004 | 03:42 PM
Tom Blasing's Avatar
is the Mighty Favog
#1 plug is on the passenger side, closest to the fender and the firewall. If your sitting in the car it would be on the right side.
Old Aug 19, 2004 | 10:16 PM
i was messing with the right one then
Acura604
20
Aug 5, 2017 12:55 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
malvothegreat
Sep 29, 2015 12:38 AM
h22lude
Sep 27, 2015 06:22 PM
