if i can't find 5w20 whats my next choice?
not sure who makes a 10w-20, but I only used 5w-30 in my car. The 5w-20 was started only in 2002 to improve Hondas fleet MPG figures a fraction of a point. The CL-S with the same exact engine seliing in 2001 only recommended 5w-30.
Other oils that will suit quite well are
Mobil 1 0w20 or 5w20 or the 0w30 and the 5w30
RedLine 5w20 or 5w30
Royal Purple 5w30
I have used all of these and got pretty much the same gas mileage.
The one I do noy use anymore is the Castrol 0w30 (made in Germany).
Its THICK 30 weight and used a little more gas.
J
Royal Purple 5w30
J
you can use 5w30 thats what they recomended up to like 2001
Originally Posted by 99bluetlwtt
I have a 99TL recommended 5w-30, can I use 5w-20?? Will it be better mileage for me too?
Initial D
Originally Posted by demolition_x
can't find enough 5w20 so far out of my 4 places to search only one had 1 qt. whats my next weight to go with
Initial D
I went to a pepboy but they only have 5w20, 0w40, 5w30, 10w30. Personally I would go for 0w20 but it is discontinued, so my next choice is 0w30
0w20 is better than 5w20 and 0w30 is better than 5w30 because you got thinner oil (lower viscocity) at startup - when 90% of engine wear occurs. The engine needs 10 at operating and startup temperatures. No oil is close to 10 at startup temperature, but you can choose an oil that has relatively low viscosity so the engine will reach 10 sooner.
0w30 is 8 lower than 5w30 at 40 degrees while keeping at 10 at 100 degrees.
See Mobil 1's spec
0w30
SAE Grade 0W-30
Viscosity, ASTM D 445
cSt @ 40ºC 56
cSt @ 100ºC 10.3
Viscosity Index, ASTM D 2270 175
5w30
SAE Grade 5W-30
cSt @ 40º C 64.8
cSt @ 100º C 11.3
Viscosity Index, ASTM D 2270 169
5w20
SAE Grade 5W-20
cSt @ 40º C 48.3
cSt @ 100º C 8.8
0w20
SAE Grade 0W-20
cSt @ 40º C 43
cSt @ 100º C 8.4
Viscosity Index, ASTM D 2270 165
See Mobil 1's spec
0w30
SAE Grade 0W-30
cSt @ 40ºC 56
cSt @ 100ºC 10.3
5w30
SAE Grade 5W-30
cSt @ 40º C 64.8
cSt @ 100º C 11.3
5w20
SAE Grade 5W-20
cSt @ 40º C 48.3
cSt @ 100º C 8.8
0w20
SAE Grade 0W-20
cSt @ 40º C 43
cSt @ 100º C 8.4
0w20-5w30 any thing in that range is fine. the early tl-s were rated for 5w30. the only reasn they went to a lower rating was to meet CAFE standards
Initial D
Kris is right, but if you want better startup protection then go for Mobil oil that starts with 0. 40 degree Celsius = 104 degree Fahrenheit, that is not the startup temperature unless you are in Arizona or Vegas. Realistic startup summer temperature in California is more like 60-70 degrees - the difference in viscocity is even bigger than at 104F. Now if you get to 32 F at winter, the difference is huge.
That being said, go with whatever weight you are comfortable with, life is too short
if you do alot of stop and go or ideling the heavier weight may be better
Initial D
http://63.240.161.99/motoroil/105.html
Motor Oil 105
Part Five. Let’s use top gear:
Let’s go racing. I will discuss driving in traffic jams in the Florida summer as well as racing in Sebring though there is no commonality. People lump these two driving situations together but there is no overlap.
On the race track one usually uses all the BHP their engine can give them. You briefly step on the brakes for the corner then put the pedal to the metal the rest of the time. Your oil will get up to 302 F, but your cooling system is around 212 F. The engine produces tremendous heat but can only pass it off so fast to the cooling system. There is a lot of air moving past the cooling radiator so the antifreeze / coolant is able to get rid of the extra heat from this part of the system with relative ease.
The temperature of oil on your gauge is not as hot as it really gets. This temperature is an average with oil from different parts of the motor. Some parts are hotter than others. It is said that some of the oil gets as hot as 400 or 500 F in these racing situations.
In an earlier section I said that thicker oils are usually needed in racing situations but not necessarily. Remember that a major function of oil is to cool the inside of your engine. In ASTM D 4485 3.1.4: “Terminology: Engine oil- a liquid that reduces friction and wear between moving parts within an engine, and also serves as a coolant.” Since the oil with a viscosity of 10 cS at 212 F thins to a viscosity of 3 cS at 302 F we will get more flow. The pressure will go down some as well. This is OK as long as we have a minimum of pressure to move the oil.
This increased flow will result in increased cooling by the oil. This is a good thing. You would probably want more oil flow in these situations and you get it. The hotter oil thins and this increases flow. The higher flow works harder to separate the engine parts that are under very high stress. It all works out for the better. Higher revving engines need thinner oils. You do not necessarily need to go to a thicker oil while racing. Only experimentation will tell.
The best way to figure out what viscosity of oil you need is to drive the car in the conditions you will use. Then use the oil viscosity that gives you 10 PSI per 1,000 RPM under those circumstances. For some reason very few people are able to get this simple principal correct. I cannot explain further.
These same rules apply to engines of any age, loose or tight. Just because your engine is old does not mean it needs a thicker oil. It will need a thicker oil only if it is overly worn, whether new or old. Yet the same principals of 10 PSI per 1,000 RPM still apply. In all cases you need to try different weight oils and see what happens. Then choose the correct viscosity.
I am using 0W-20 in my Ferrari 575 Maranello right now. It has over 5,000 miles on the clock. There will be a day (my estimate is 50,000 miles) when I will have to go to a 0W-30. In the future I will have to increase the viscosity to a 0W-40, then a 0W-50, maybe. I will use whatever it takes to give me 75 PSI at 6,000 RPM during the lifetime of my engine. This formula works in all situations.
Some people have tried this and occasionally get a somewhat low oil pressure while at idle. This is fine. There is no stress on parts at idle, the smallest oil flow will do the trick. It is at higher RPM where more BHP is produced. This is where we need the flow. Remember that Ferrari uses 75 PSI at 6,000 RPM as the place to test your oil viscosity needs. If your oil gives this value under your driving conditions then your lubrication system has been maximized. Period.
Do not go 5,000 miles with the same oil if you are racing your car. You should change the oil every 1 or 2,000 miles. If you drive your car around town then you need to change the oil for that situation. Use racing oil on the track and urban oil around town. The best situation as described by Ferrari is to use the 0W-40 around town and the 10W-60 “racing oil” on the track. It has to be that “hot” track though. A compromise situation would be to use the 5W-40 for both but this may not be optimal. Certainly, if you are just an urban driver as me use the 0W-40 or even a thinner oil as I do in my Maranello. Again, I use the 0W-20.
FYI. The Formula 1 cars that run at 15,000 RPM and higher use straight 5 and 10 weight oils.
Now let me discuss what people think is a similar situation to racing. That is hot summer traffic jam driving. Your car should be able to handle this. If you have problems then you have a problem with your car, most likely in need of a cooling system overhaul.
When you drive that car down the road mid-winter in upstate New York or mid-summer in Florida the engine and oil temperatures will be around 212 F. But your Florida vacation is suddenly altered by a hurricane. You have to get out of Tampa, but so do a million other people. It is now 95 F and you are in a snarl. Everyone thinks they need a thicker oil for this situation. This is false.
Your engine is not producing much heat at low RPM and low BHP output. The production of heat is relatively slow. It can easily be transmitted to your cooling system. The problem is that your cooling system has trouble getting rid of the heat. The oil and the coolant will slowly rise in temperature. They both rise together. The increase is no big deal for your oil. It goes to 220, then 230 F. The problem is that the cooling system can only handle heat up to 230 F. After that you overheat the cooling system and the car must be shut off. The oil never got that hot, It was just that the water got a little hotter than its system design.
You now see that overheating in traffic is a cooling system problem and not an oil system problem. Do not change to a thicker oil based on your traffic situation.
this is a double edged sword ^. yes its true, but most dont use it to cool. we all rely on the radiator to cool the car. the main reason for teh heavier weight iol is to provide better and longer lasting lubrication under severe driving situations.
i have had better TBNs' using 5w30 over 0 and 5 w20 oils as mentioned above. yes it will rob a few ponies, but teh extra lubrication and stress handeling abailities is what i would perefer. my car idles all day long and the 5w30 has consistantly shown to last longer in my application
Oil brand recommendations
Royal Purple 5w30
J
Royal Purple 5w30
J
09-25-2015 06:14 PM
maharajamd
Console & Computer Gaming
09-24-2015 03:31 PM
4drviper
09-23-2015 07:42 PM
