Idle issue
Old Feb 18, 2011 | 11:29 AM
Kronos89's Avatar
Unhappy Idle issue
I noticed my tl idling funny yesterday, it seem like it wanted to turn off. but it only happened once, this morning i took it for a spin, and it shut off while idling. once i put it in drive, it goes and no problem. But once i turn it off, then back on the car turns off. Could this be an ignition issue-the part was never replaced under the warranty. The car runs fine, except for the idling. Car only has 27000. Any advice or suggestion will be appreciated.
Old Feb 18, 2011 | 02:09 PM
fsttyms1's Avatar
Does the RPM drop when this happens? Does the engine run rough?
Old Feb 18, 2011 | 02:25 PM
swoosh's Avatar
takin care of Business in
O2 sensors or something to do with your Cats....could be spark plugs/wires too....
do you have a check engine light on ?
Old Feb 18, 2011 | 06:36 PM
01tl4tl's Avatar
is it a 99? those had the ignition switch recall--talk to your dealer if it wasnt done before.
does wiggling the key make a differance, cause it to stop engine
Old Feb 18, 2011 | 08:57 PM
Kronos89's Avatar
Yes i called the dealer and told me to bring it in, because it was never changed. no wiggling needed. the rpms drop too much and it turns off. starting it back on and giving it gas for a few seconds stops it. i have no idea what could it be, but the dealer is giving me a loaner, because apparently this takes a bit.
Old Feb 19, 2011 | 10:31 AM
01tl4tl's Avatar
if its the recall part- ignition switch- they may have to order from warehouse
not something they need taking up shelf space
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
Mike Bertram
Sep 10, 2015 09:27 AM
NSolace
Sep 3, 2015 08:14 PM
