IACV and egr cleaning question
my TL sometimes while sitting in traffic likes to idle a little lower than where it should and it doesnt really idle rough or anything, bout i can feel when it happens. I cleaned the egr ports already and i was wondering how to clean both the actual valve itself and the IACV, to me it sounds simple(just take off and clean parts) but i have read threads where they took it off and put it back on and they had a surging idle. My real question with that is what exactly the dos and dont's of the IACV
IACV is inside the TB on the bottom- 2 screws hold covr on - do replace gasket for cover so no air leaks
remove its rod and clean air slit and the bore it fits in
to clean egr - you removed the intake manifold from car and used 3 cans carb cleaner and a wire coat hanger to poke all the way thru length of manifold passage?
And removed the egr valve itself to clean the 2 holes under it - into the passage?
removal of manifold and TB without setting TB aside can result in shaking up crud or other issue inside IACV that causes rough running
IACV = Idle Air Control Valve
DO replace gasket from TB to manifold
ck the small hoses for the TB heater, if swapped with a vac line in the same area- it will run really bad!!!
@01tl4tl I did the egr port cleaning this past weekend and when it came to cleaning the port that leads to the egr valve its suppose to be a clear passage that flows straight through correct? I used carb cleaner to clean all the build up out but it seems like it was totally blocked further down the passage. I tried the wire hanger but had no luck getting through. The carb cleaner would pool due to the blockage. Any ideas on what to do?
99s had a recall that slightly enlarged the 1 port at cylinder and inserted a smooth bore into it- was supposed to cut down on the problem but did not
later years got 6 egr ports! still clogs!
you MUST spray and poke until it flows thru
anything less is slill blockage
3 cans of carb cleaner is common to get it all loose and out
Deep Creep works very well on this job too
and that wire coat hanger!
cycdaniel
Dec 17, 2019 10:58 AM
