IAC Valve 5 point screwdriver
Hey guys,
I've been having problems with my IAC and followed the DIY to clean it. The only problem was that my IAC valve had two FIVE POINT (NOT TORX) screws that attached the sensor portion to the actual valve. Does anybody know where to find this type of screw driver? I cannot get the valve completely clean without removing this sensor and i'm having terrible idling issues
Originally Posted by SSMTL01
Hey guys,
You shouldnt have to take that off to clean the valve. I went and played with the one i have laying around and i was able to take a small flat head screw driver to remove them (though i believe you are the first to try to do so to clean)
feel free to move me...
i used a moderately size flat head screwdriver, and was able to get one off, and then a pair of needle nose pliers to get the other off as soon as I started to strip the second.
if you grab the head of the screw with the needle nose pliers much like turning a bolt or nut with a wrench, not a screwdriver technique, you can maximize the torque and get the screws off.
of course I only chose this method because i had things torn apart and no way to get to an auto parts store at 11pm.
The solenoid rotates a small valve to regulate the idle speed of the vehicle. What generally happens is this small valve gets gunked up with carbon and can not rotate freely.
ABOUT THE VALVE: The way the valve works is pretty simple. there is an inlet hole, and and exit hole. the valve it the shape of a cylinder with a wedge cut out of it. when the engine needs more air at idle, the solenoid rotates the cylinder so that the wedge portion is halfway between the two holes, and air can flow from one side to the other.
once I got the solenoid off I recorded the direction of the small tab sticking out the end of the valve so that when I inserted the solenoid again, everything would be where it left off.
then you can easily remove the cylinder, and clean it with some throttle body cleaner or alcohol or whatever volatile chemical you happen to have...j/k stick with carb cleaner, a rag and a q-tip for inside the wedge.
Once all clean, insert the cylinder into the valve assembly and check for free movement. You should be able to spin it freely.
rotate it to the position you recorded earlier, attach the solenoid and screws and you should be ready to put everything back together!
i was also thinking of removing the sensor, didnt want to damage it with the carb cleaner. If i keep the sensor connected i would just spray in the metal openings, and scrub with a toothbrush or something?
third item down the main gen2 thread title list= Official DIY List
rare is the bad iacv- often is the carbon clogged air slit and crudded chamber that needs a simple service
dont forget to clean the TB air plate on both sides and edges,
lube the throttle return springs
Jamus22
Jun 11, 2023 10:08 AM
