i think i have a bad wiper arm, how do i remove it?
Ive got a 02 tls and the passenger side wiper arm wont go up anymore. I removed the cap covering the bolt for the wiper arm and its turning so I'm assuming that the motor is fine and the arm needs to be replaced.
I just cant figure out how to take the arm off. I've removed the one bolt but the thing wont slide up or budge at all. How do I do this?
ok i jiggled it and it came out. it looks like the "teeth" below the threads for the cover bolt are stripped. What part do I need to replace to change that?
Also, it looks like the the "teeth" that are in the wiper arm are stripped too. Looks like I will definitely need a new wiper arm but I'm not sure what part to get for the stripped teeth below the threads for the wiper nut.
If the splines on both are stripped out you may need part #10.
CheeseyPoofs McNut
10-11-2015 11:25 AM
