I need some help
I need some help
if i cant do anything with this i can put the same part of a acura tl 2004 my acura is 2001 base
heat it with a torch and pound that bad boy out. Be careful not to burn ABS wire or anything non-metal in the area. If you can, pull the strut with fork attached and work with it on a vice.
I don't remember for sure, but I think I was able to remove my coilovers with fork attached.
It was long time ago, so don't remember if I had to drop anything or it was something simple like pushing wheel hub down.
Hope you managed to take it out by now
