I need the oem fog lamps
Old 05-11-2010, 06:43 PM
Walfunk's Avatar
Question I need the oem fog lamps
Dealer wanted $504 which is absurd to me...Where should I get them and about how much should I pay? Mine still work but driver side has huge piece of lens missing and passenger side is cracked....
Old 05-11-2010, 06:51 PM
nug87's Avatar
There is some on ebay.
http://cgi.ebay.com/ebaymotors/PAIR-...Q5fAccessories
Old 05-11-2010, 07:34 PM
B A N N E D
friesm2000's Avatar
that a little high, but not extrodinary though, they are expensive suckers, but yeah i had to replace my driverside one though, cause of holes punched in it, and my passenger side is still cracked, but not leaking though, so that can stay in for now
Old 05-11-2010, 08:17 PM
piggylover1985's Avatar
Try Ebay, car-parts.com, if it just for 1 foglight assembly shoudn't cost that much at the dealer, maybe for a whole complete kit, but then i could be wrong.
Old 05-11-2010, 08:30 PM
B A N N E D
friesm2000's Avatar
it's like $200 JUST for the housing alone, not even including a new bulb, but you get a perfect lense then though
Old 05-11-2010, 08:36 PM
Wow, even that's expensive.
Old 05-11-2010, 08:48 PM
B A N N E D
friesm2000's Avatar
so really that $504 is really not that bad afterall, when you take into account of just the parts (basically an hour of labour, if that is also installed)
Old 05-11-2010, 08:49 PM
B A N N E D
friesm2000's Avatar
sorry $143 here plus shipping, or $191 list price
http://www.hondapartsunlimited.com/i...&submit=submit
Old 05-12-2010, 12:41 AM
'03TL-S's Avatar
I need to replace mines too. Has a hole in it!
Old 05-12-2010, 12:51 AM
It's the Halladay season!
hANDYcaptd's Avatar
If the damage is just the lenses, I would do the Lexan replacement and save a shit ton of $$
Old 05-12-2010, 07:29 AM
Walfunk's Avatar
Thanks for all the info...the damage is just the lenses...what is the Lexan replacement?? That sounds like that the trick...thanks fellas
Old 05-12-2010, 07:32 AM
Walfunk's Avatar
do you mean this?? https://acurazine.com/forums/2g-tl-1999-2003-98/lexan-fog-light-fix-painted-fog-lights-diy-694354/
Old 05-12-2010, 08:13 AM
tri2tun's Avatar
^^^x2, sounds like it's just the lenses that need fixing - just bake them, pry 'em open, and replace the lenses. This is much easier to do than with the headlights.
But if you wanna replace 'em, why not try the local junkyard? They probably will give you both for ~60-80 bucks.
Old 05-12-2010, 11:52 AM
hANDYcaptd's Avatar
Originally Posted by Walfunk
Yep
Old 05-12-2010, 12:47 PM
The Dumb One
Rockstar21's Avatar
i wish i lived in a state where the cars were newer then a 95'
Old 05-12-2010, 06:21 PM
Walfunk's Avatar
LOL! on the newer than '95 comment...yep, looks like the salvage yard for me....both for under $100 sounds good to me...no way i'm doing that whole bake and pry off thing..no time or patience...thanks again for all the info!!
Old 05-12-2010, 06:31 PM
ARide for Life
Slow Type S's Avatar
go to home depot get some lexan and cut it. i had this done to one of them and it held better than glass.
if anyone wants a spare set to try it on i have a cracked oem set for sale for like $40 bucks on the BM
Old 05-12-2010, 08:06 PM
B A N N E D
friesm2000's Avatar
only issue i had, was that it had been like that for a long time though, so the chrome inside was already corroded and such badly, so couldn't really do that too easily without painting the inside and such
newer then 01 here, nobody has 02-03 parts here
Old 05-12-2010, 08:07 PM
B A N N E D
friesm2000's Avatar
upper right area in the picture
Old 05-13-2010, 04:59 AM
Walfunk's Avatar
Do you HAVE to pull the bumper off to replace them?
Old 05-13-2010, 02:05 PM
B A N N E D
friesm2000's Avatar
no, not really but pulling the bottom out a little on the bumper, might help you be able to reach the 10mm bolt holding each side in (you need probably like a 9-12 inch extension though iirc, to reach it)
Old 05-13-2010, 06:35 PM
Walfunk's Avatar
Ohhhhh..ok..thanks FriesM2000....will take a look at it this weekend, then go hunting at the local junk yards.....maybe i'll get lucky...
Old 05-13-2010, 08:07 PM
Tomb Acura's Avatar
Foglights
Check out Rockauto.com
I bought them for about $110.
They fit perfect.
Old 05-13-2010, 08:11 PM
Tomb Acura's Avatar
Easy to replace
It is a 10 minute job to replace. You will find access holes under the bumper. Lie on your back on under the bumper and you will find a square access hole. Use a 10 inch extension with a 8 mm socket to release the hold down screw. Very easy.
Old 05-14-2010, 05:07 PM
Walfunk's Avatar
Now thats what i'm taking about! Thanks Tomb!!yessssss!!
Old 05-14-2010, 05:10 PM
Walfunk's Avatar
2003 ACURA TL S 3.2L 3210cc V6 FI [J32A2] SOHC : Body-Exterior : Fog/Driving Lamp AssemblyPriceCoreTotalTYC GENERA Part # 19559400 {#33951S0KA11, AC2592104}
33951-S0K-A11; Left- Stocked in outlying warehouse--shipping delayed up to 1 business day
$89.89$0.00$89.89
TYC GENERA Part # 19559300 {#33901S0KA12, AC2593104}
33901-S0K-A12; Right- Stocked in outlying warehouse--shipping delayed up to 1 business day
$89.89$0.00$89.89
VARIOUS MFR Part # AC2592104 {#33951S0KA11, 33951S0KA12}
w/o bulb or socket; 3.2TL; LT Fog lamp assy (Only 4 Remaining)
$97.79$0.00$97.79
VARIOUS MFR Part # AC2593104 {#33901S0KA12}
w/o bulb or socket; 3.2TL; RT Fog lamp assy
$97.79$0.00$97.79
SHERMAN Part # 00021251 {#33951S0KA12, AC2592104}
LH fog lamp Acura 3.2tl 99-03
$105.79$0.00$105.79
SHERMAN Part # 00021252 {#33901S0KA12, AC2593104}
RH fog lamp Acura 3.2tl 99-03
$105.79$0.00$105.79
Old 05-14-2010, 05:11 PM
Walfunk's Avatar
opps didn't meant to post above....Tomb, you got BOTH of them for $110?? If so, how??
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
rockyboy
09-29-2015 12:05 AM
Eggs999bacon
09-24-2015 10:08 AM
Quick Reply: I need the oem fog lamps
