I love that big brown truck
08 Civic SI
just got my greenstuff pads today. but i have a few questions.
1. do i need to use the stock shims(i think thats what they are called)
2.where on the pad do i apply the anti squeel stuff
3. what are those black tabs that are sticking out of the 2 pads on the right?
this is my first time changing pads by myself so i dont wanna screw anything up
FPR pimpin'
i believe the anti squeal stuff goes on the part where the pad rests on the sliders, and the black parts are the squealer pins so when the pads are almost dead it will squeal.. i think never changed the TL brakes before.. i imagine keeping the shim would be a good idea
When you take it apart you will notice the tabs on the inner pads- make sure to put the correct pads in each side
The "grease" goes on the black parts where you see wear on the old ones- the contact points- you will see-
the shims/backing plates- built into the new ones- do not use the old ones
And a little on the slide areas
Buy the tool for 5 to 8 bucks that pushes the piston into the caliper
So much earier than c clamp or giant pliers or ....
You have a 99- may have the screw in type pistons or the push in
If 4 cut in tabs on caliper piston- screw in type
Go read the threads on replacing brakes for all the tips you need
And read and follow the pad bedding in procedure
L3
If you have never changed the TL brakes and have only a guess as to what goes on- why are you offering up advice?
This board is full of skilled people- and most questions can be answered by a search or simpe scroll thru the threads
hehe.. couldn't help but notice...
orgnlprankster7
Let your stupid flow
Your questions aren't dumb at all... it just tickled me a little to see that under your name
orgnlprankster7
08 Civic SI
so i take it i do not need to use the stock shims as the black thing on the new pads are shims. also when i go to push the piston back in, wont that put air into the sytem? should i pop off the reserve brake fliud tank cap so air can escape?
Heres a do it yourself link for you to follow up on
http://www.edmunds.com/ownership/how...7/article.html
Good luck
Good luck
08 Civic SI
Good luck
Good luck
You buy anti squeel at auto parts for a buck for the tiny pack needed for the job
The backing plates are preinstalled- use the original ones as book markers
DO NOT OPEN THE FLUID CAP
Pushing the piston back in place does not create air bubbles- it is a sealed system
You WILL raise the level of fluid in the Master Cylinder UP- so if its close to the topfull line because you filled it recently- then use a turkey baster (new-not from kitchen) to remove half the fluid and you will be fine.
Pushing the piston in slowly helps too.
Spray brake fluid everywhere by taking the cap off and pushing the pistons. BAD
BUY OR BORROW the caliper service tool- for 8 bucks makes the piston job a snap
read the brake DIY info linked above so you know about tight bolts.
Get a knowledgable friend to help you- soundls like your very first time doing this
When all done- before driving- pump brakes several times to push the calipers out and onto the new pads or you will have no brakes as you roll into the street
Congrats on a job done at home!
Go back and recheck everything is tight after a drive and the wheel lugs too
Follow the break in procedures for the EBS pads and you will enjoy them much more.
Originally Posted by orgnlprankster7
thanks all, i just did this. took me 15 min! just looking at it i knew what to do wasnt as hard as i expected.
Now why don't we discuss a Mercedez dealership who charged my parents 2 hours of labour (at $110/hour) for changing two rear break pads....
08 Civic SI
08 Civic SI
Originally Posted by red00tl
Good work. 15 min is pretty good for the first time.
haha...15 mins? Pretty damn fast...good job
OPrank
That noise should reduce or go away as the brakes get some use on them
Again- follow the break-in directions that should have come with the pads to the letter.
Usually you would clean the rotors with something (like fine wet/dry sandpaper) if not resurfacing or replacing them to remove remains of original pads from the rotor.
The contact transfer material of pad to rotor is critical.
See makers website if not included in the directions
09-25-2015 06:14 PM
