I have found a less expensive solution to our rotor problems...
I Have Found a Less Expensive Solution to our Rotor Poblems...
I discovered this weekend that NAPA's Ultra Premium rotors carry a lifetime warranty against defects. I called two different NAPA stores in two different cities, and they both told me that if the rotor warps before it is worn to the discard thickness, they will replace them at no cost under warranty.
While these rotors will not hold up as well under high-performance use compared to the Rotora, RacingBrake, etc, they will work great for many daily drivers. As far as I can tell, they are repackaged Raybestos Advanced Technology Rotors, which are Raybestos' top-of-the-line offerings.
The part # is UP 86795. The list price is $73.49, but the price is probably going to vary between $60-$75/rotor depending on the NAPA location and the discounts that you qualify for (e.g. AAA).
Something is missing...my
Or, for $75 bucks a pop, check out racingbrake setups. They are great quality materials and good company not focused on production volume, but braking performance
In addition, Racingbrake rotors are about $120/rotor compared to the $60-$75/rotor that these cost. I do not disagree that Racingbrake rotors work well and are superior to these especially under high-performance use, but there are many of us who do not require that level of performance. A good quality OEM replacement rotor with a lifetime warranty (life of the rotor) against warping would satisfy many members.
pad determines performance under standard conditions. Rotor dertermines those conditions. the racingbrake rotor is designed SPECIFICALLY to keep the rotors cooloer under braking making normal street brake pads more capable of providing friction without fade. This being the case, coupled with the fact that they use better metal than United (guaranteed) they will also be MUCH less susceptible to warpage and cracking, making them LESS expensive in the long run. They have a couple of options that are designed for braking performance depending on your needs/desires.
Note: less expensive part, does not equal less expensive solution. Period
Nice, thanks for the info. For someone who just does regular driving/commuting this seems to be a great alternative. If you drive agressivly or track your car on the weekends Racingbrake should be the other option.
Don't take me wrong - you WILL spend less but just to give an example:
My wife, (aka grandma driver) had her 3G TL (identical rotor and caliper setup) for not too long before her rotors were begining to shimmy. So, I am not just saying "spend more money, I did." On the contrary, I am saying "save money in the long run (invest)." Not to mention who wants to deal with new rotors all the dang time, even if it is warrantied. So, even if you are not a "track driver," you will definitely benefit from the better rotors. My wifes car has the lesser of the two RB rotors and they are great even with the OEM pads. I on the other hand have the 2-piece with RB pads and I love them too, more for performance and weight saving reasons.
Also keep in mind that replacing the rotor does not always address the root cause of the pedal pulsation.
If you have excessive runout on the hub assembly, regardless of whether you install Napa, Racingbrake, Rotora, etc rotors, the problem will return. This is why runout should always be checked after the new rotors are installed. You should always index the rotor to the hub and find the mounting position with the lowest runout. Overtime, excessive runout will cause disc thickness variation, which is one cause of pulsation problems.
Runout is a problem, yet when a 1.5 year old car has steering wheel and pedal shake, which were remedied by the new rotors, there is very little argument for runout. Further, find a shop that checks hub and disc runout when there are vibrations under braking and I will refer everybody I know to them . . . doesn't happen. Most will slap new rotors or spin existing ones and pads $350 please. Thank you very much.
Buy quality and save money
I don't know which shops you're going to, but nearly all of the shops that I take my cars to do check rotor runout either with a dial indicator or with an OCL before and after servicing.
I don't go to shops. Worked there during college, been there, done that, know how techs treat cars, and that very few shops emphasize high quality work.
02 NBP TL-S W/Navi
the one cure for rotor warpage i had on my Civic was to find a shop that resurfaced the rotors while they were still installed on the vehicle. on some of the newer cars thats what the auto manufacturer recommends when doing a brake job, is to service/resurface rotors while still installed on vehicle.
on the car lathe is nice, but they started doing that due to the presson rotors of 90-94 on the accords and equivalent.
variation of the lateral (sideways) position of the disc surface in relation to a fixed point. Think warping. The idea is that a hub may have its own runout, and therefore cause the shimmy in the brakes even if rotors are not warped. I think it is a myth! haha
If this was a myth, manufacturers would not require an on-the-vehicle lathe. Limits for runout have become less and less over the years. For example, a G35 only allows 0.0014" of runout for the front rotors. In the past, anything less than 0.005" was acceptable.
haha, they said explain, in other words giving analagies to help the comprehension. It is only a myth cause I knew you would FREAK when you read it!
OCL's as you refer to them also account for warpage, not just runout
Warping is a generic term, not alway variation in thickness, can also be variation in lateral position/runout. If you have spun rotors on a lathe, you will know this to be true.
That isn't true.
You can have 0.005" of runout immediately after a brake job and you will not have any pulsation problems. Why? Because the caliper will move WITH the runout.
Only after a few thousand miles (after the high and low spots exist) will the pedal pulsation be felt--that's because the thickness variation has developed.
If your caliper is causing the pads to hit the rotor at any point of rotation - after bedded in- you probably installed OE shims on top of the shims attached to the replacement pads!!
If there were ongoing contact you would eat brake pads- as verified by anyone who has experienced a failed caliper in the partially ON position
On the average TL- its not an issue of hub runout- much as some with freaky brake probs would like to believe
If you had an encounter with the curb- you bet there could be an issue with hub- now!
but in the average case- its stock rotors that cant take the heat generated- its not like OE is the best stuff made- just the best price-lowest price to the factory
While I would NEVER recommend reusing OE shims on aftermarket pads, the caliper piston will compensate for the added thickness of the OE shims. This will not be the cause of the problem.
the caliper piston is only on one side of a stock caliper TL- we are talking about
Some recent threads on the exact prob of installed pads (on a brembo no less) and used double shims- boy did that take up the 1mm clearance the pads normally sit off the rotor~
Soda- you are not the endallexpert- neither am I- but I have worked on cars professionally- for decades,-- I learned a lot in that time, and have been in my 01s brake system and a few other ziners several times now- which gives me a bit of insight to certain problems
You are on a warped hub rampage- and I have not seen one example of a TL with that as the cause of crappy rotor syndrome
Originally Posted by SodaLuvr
That isn't true.
So, have you yourself lathed rotors, or no?
Originally Posted by roxburydog
hate to sound slow but is runout/warpage a common problem with 3gen TL's?
Ok, so what did I say that wasn't true? I said OCL accounts for warpage and runout at same time. True. I said lateral variation is a form (more common than thickness variation if I were to say) of warpage to. Warpage is a generic term. True.
I guess if you want to use "warpage" as fairly generic term, then I guess you're right. But generally, warpage is referred to the common disc thickness variation that causes pedal pulsation, not runout.
Back to the original intent of this thread when Soda found a cheaper alternative for rotors at $75 each for front- standard- non slotted- is that correct soda?
What brands are being compared with the bendix-?
we need apples to apples comparison, not RacingBrake or Rotora to Bendix or Raybestos, which local stores sell for nearly $100 each- that pushed me to get hi performance stuff for a few dollars more
but thats me
but thats me
but thats me
but thats me
Bendix ???
ok but how does their price compare to other brands
What makes these rotors the cheaper alternative??? thats my question
I never got a 20 percent discount with aaa card- napa gives a little but not much
My local NAPA store sells it for 65.69.
AAA gets another 5% off (or so).
Like I've said, the NAPA Ultra Premium rotors are repackaged Raybestos Advanced Technology rotors. Their quality and price are competitive with the premium offerings from other brands.
