howling noise.. help??
i had this problem ever since i got the car. By reading some treads on howling people have said its wheel bearing related.
Mines does the same thing over 60mph but gets louder and high pitched as u go faster, can it be Tire noise? i have Dunlop signature series tires 205/60r16. Any one use these tires and have tire noise?
need more info- year- miles- does noise vary? have you listened to the wheel bearings with stethascope?
find a shop to put on the lift- spin the tires and listen- they can hear whats bad
could be cv bearings or rear wheel bearings or.....ps pump or ac idler pulley or...
It has around 78k miles on its an 2003 its the same constant noise
take it to an alignment shop or a private repair shop that does acuras/imports
Need to get bad noises checked right away, its could be one end of the axle/cv bearing or something else
