How is the TCS button supposed to work?
Old Aug 22, 2012 | 03:02 PM
SnoMann's Avatar
9th Gear
My button doesdoesn't have a light on it like the cruise and it also doesn't light up anything on the dash. Its momentary also, not like the cruise switch. My question is what is supposed to happen when you engage the switch? Its possible I have some burnt out bulbs or a bad switch or maybe whatever controls the TCS. A little insight would be great. Thanks
Old Aug 22, 2012 | 03:11 PM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
When you press it, it is supposed to stick and there should be a light in the bottom left of the gauge cluster that comes on yellow and says TCS. That disengages the traction control system. Once you press it again the light will go off and it will re engage the traction control system
Old Aug 22, 2012 | 04:00 PM
SnoMann's Avatar
9th Gear
Thanks! Looks like I need a new switch... Is the TCS dash light supposed to come on when you key the ignition on?
Old Aug 22, 2012 | 07:12 PM
Yeah it comes on for a second or two then shuts off
Old Aug 22, 2012 | 08:58 PM
01tl4tl's Avatar
register by cars VIN with www.owners.acura.com and download a free owner book for your car
all the info on switches and what they do and driver tips are in the book
unless you are tryiing to get up an icy driveway,,leave TCS ON meaning no light on dash
'light on means system is OFF
also register with acura care 1 800 382 2238x5 as owner
ask if all recalls are taken care of
Old Aug 22, 2012 | 09:26 PM
Skirmich's Avatar
Didnt TCS worked only below 10mph anyway???
I Believe once you go Up 10mph it wont do anything.
Old Aug 22, 2012 | 09:52 PM
yes it only works up to like 8 or 10 mph
Old Aug 22, 2012 | 10:06 PM
SnoMann's Avatar
9th Gear
So the light on means the tracion control is off? I do have an owners manual but it didnt really explain much. But it was a little late the first night after I bought it and Id had a few tall boys... Maybe I'll read through it again. Thanks 01TL
Old Aug 22, 2012 | 10:20 PM
Sperry's Avatar
2000 TL Black on Beige
The bulb is a few bucks.
Old Aug 22, 2012 | 10:22 PM
Sperry's Avatar
You can ship me a few of those "tall boys", and we'll call it even [ha-ha]
Why ever in hell Acura choose to use so many different dash bulbs continues to befuddle me.
Old Aug 22, 2012 | 10:45 PM
Skirmich's Avatar
Yes if the TCS Light in the Dash is ON then TCS is Off (Hahaha)
Just like the VSA System shows a (!) Triangle when you Turn it Off..
If that works then you just need the Bulb Inside, My Fog Light switch also needs a bulb the green one (The One that Turns On with Fogs) just died on me but the Fogs still works.
Old Aug 23, 2012 | 09:13 AM
01tl4tl's Avatar
TCS only works up to 16 mph (25kph) then quits
Its intent per book- is as stated,,icy driveway example
dont turn it off,,leave it alone for most cases
Old Aug 23, 2012 | 01:14 PM
fsttyms1's Avatar
The TCS button is momentary. It doesnt push and stay. Once the car is turned off and restarted the system defaults to on.
IMHO, TCS in the TL is a waste and a joke that doesnt work. I personally find a system that shuts off as early as it does useless. GIve me something that keeps the wheels from spinning at hwy speeds when on black ice and snow. That is useful.
Old Aug 23, 2012 | 03:48 PM
Sperry's Avatar
Exclamation Hope this is helpful.
Old Aug 23, 2012 | 05:04 PM
05_NBP_TL's Avatar
HE>i
Old Aug 23, 2012 | 05:13 PM
Skirmich's Avatar
God Bless VSA + ABS 4 Channel on the Type-S
And I love how in the Pic ABS Still take longers to Brake than when you dont have it ROFL...
Old Aug 23, 2012 | 08:57 PM
fsttyms1's Avatar
Originally Posted by Sperry
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
acurajj
Sep 19, 2015 03:47 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
Charlespsu
Sep 2, 2015 09:54 AM
