How to replace front corners?
Old Aug 2, 2001 | 07:03 PM
SimTypeS's Avatar
...and then there was One
Question How to replace front corners?
I'm trying to replace the amber bulb up front with a PIAA Xtreme White Bulb. Does anyone know how to replace it? I searched, but no luck. TypeSDragon said he has done it. I don't have the manual someone has mentioned that tells how to do that stuff. I have a TLS. Also, if anyone knows how to find state laws on what bulbs have to be what color, it would help. Thanks.
Old Aug 2, 2001 | 07:10 PM
You have to take out some screws in the wheel well. You then pull out the black plastic modeling as far as you can and reach in with your hand. If you feel around you should find a back of the corner light. To take it out just twist and pull.
Old Aug 2, 2001 | 08:59 PM
wiggingboy's Avatar
Its very easy...... just go under where the wheel and there be a plastic screw. take it out and bend the black part back. you can see the light if you stick ur head under it. Just stick ur hand all the way in and twist it off.
For more instuction .. its in the owners manual.
james357
Feb 13, 2016 02:37 PM
08 NBP TL
Sep 8, 2015 08:49 PM
asahrts
Sep 4, 2015 05:55 PM
voigt
Sep 2, 2015 10:44 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
