How to replace front corners?
...and then there was One
I'm trying to replace the amber bulb up front with a PIAA Xtreme White Bulb. Does anyone know how to replace it? I searched, but no luck. TypeSDragon said he has done it. I don't have the manual someone has mentioned that tells how to do that stuff. I have a TLS. Also, if anyone knows how to find state laws on what bulbs have to be what color, it would help. Thanks.
You have to take out some screws in the wheel well. You then pull out the black plastic modeling as far as you can and reach in with your hand. If you feel around you should find a back of the corner light. To take it out just twist and pull.
Its very easy...... just go under where the wheel and there be a plastic screw. take it out and bend the black part back. you can see the light if you stick ur head under it. Just stick ur hand all the way in and twist it off.
For more instuction .. its in the owners manual.
asahrts
09-04-2015 06:55 PM
