how much am i supposed to feel the vtec kicking in?
everyone seems to say that when vtec engages, it's an obvious kick in the pants, that the engine sound changes and the car surges forward....mine definitely does not do that. so how much do you really feel it? mine doesn't seem to slack off or anything, i'm just not getting some crazy surge around the 5k mark like the above guy's face suggests i should be.
generally, the only times i really push the car are when i seafoam it (i've done so twice). no, i haven't really ever felt anything other than continued power. what screen filter?
Do you have a intake? If your running the stock intake its not very noticeable. Are you letting the motor run to redline or letting off shortly after vtec engages? Also i see you have a 99 so yours engages much earlier than 5, yours is 3.8-low 4s if i remember right.
car is completely stock. and i don't redline it on seafoam, but while...um...demonstrating the car's power to adjacent vehicles, i have redlined it. if it's that low i'll try and notice it there.
not very noticeable--summer/when it warms up project: remove resonator
philly flickin'
Its alot more noticeable when you get a cold air intake.
Just floor the car and when the rpms pass, whenever it kicks in im not sure about 99's, then just listen and pay attention to the slight pull u will feel. I've had times where I barely have traction and vtec kicks in and just breaks loose and spins. I love the sound/feeling of vtec.
^^ yeah same here when i first got the car i loved that feeling but since i've had my car i've prbly hit vtec like 5 times and i've had it for a little over 2 years... but i do remember it feels amazing...
I'm a thrill seeker in my
It's far more noticeable in the weak 4 cyl hondas than in our v6s in my opinion. Since the J series has reasonable midrange torque you're going to feel the most pull there. Vtec mostly sounds nice.
ABPUA5
hell naw man.. i dunno about you. but with a type-s with intake/exhaust, once vtec kicks in you hear the car literally scream.. you can see the needle climb quicker on the RPMS and speedo. well atleast i can
while its not a 50 HP shot of power it will make you feel accelleration forces into the seat
Quit watching Fast and the Furious. Its not like in the movies when they flip the switch for Nitrous and tail lights start blurring and you accelerating like you just went into warp drive.
The Dumb One
hard to judge exact without a high speed cam though.
and like said above OP... its def. not a nitrous feeling... but my motor was stock and you could Hear and Feel when mine was engaging.
Wildfire.ca (05-27-2016)
with a k&N filter and removed intake resonator box you can tell exactly when it kicks in
Sound goes deep and throaty, like the sexxxy beetch she is~, sound of airflow increases, slight push into seat
do a wiki search for vtec- there are pics of what it does and how it operates in the valvetrain changes
Need to keep oil passages clean (seafoam oil before change) as that actuates and runs vtec off changes in the oil pressure with rpm and throttle position
Need clean plugs pistons valves and injectors for it to work to max effect-seafoam does all that or bg or wynns or honda stuff-
all cost more than seafoam
did a little more testing today, but it was a 35 zone and wet so i had to use relatively light throttle in 1st to avoid vaporizing the tires/getting a ticket...there is a slight change in noise at about 4000rpm...that's about it. i will try it on the highway and see if i get more of a kick, 01tl mentioned it's dependent on oil pressure and my testing probably didn't increase it all that much. i have replenished my vtec and turn signal fluid as well. dunno how to check the muffler bearings, what's the life span on those things? hopefully better than the transmission
2003 TL-S w/Navi NBP
Hard to engage vtec with just normal city driving. Too many traffic lights and grannies getting in the way. I blew my helsinki smash rod last time I tried.
It is not gonna push you against the seat but you will feel it and the speed will climb faster. If you're expecting something like a NOS shot effect or movie stunt like, then lower your expectations unless you mod it like the others have said
If you don't feel your eyeballs pushing against the back of your skull, then something is wrong with your VTEC!!!
philly flickin'
The best way to notice VTEC is to go to an empty road. Turn off your traction control then put it down to D1 and use gate shifting, since our tiptronic is shit and shifts 1-2 by itself. Once you have traction at about 2000RPM floor it and make sure u have ur music off. You will hear and feel when it kicks in.
W00t
Make sure the vtec setting is turned on high, also should probably check the ground pressure. Now that I think about it, the firewall gasket leaks sometimes and that causes VTEC to malfunction. Plus since its kinda cold out, might need to fill the tires up with some winter air, I bet your still running summer air.
You wont notice the vtec pull on the highway. Once you floor it and you are in second gear, your RPMs stay above where vtec kicks in.
2008 Acura TL Type-S
What he said. The VTEC switchover is a LOT more noticeable in my RSX than my TL.
Received 2,329 Likes
DOHC VTEC motors have a far more noticeable VTEC crossover point. The gains are a sharp spike in power and noise.
S2000, Prelude, Integra etc.
The SOHC VTEC motors are more 'tame' and tuned for a broad powerband.
type S cars get different cams, intake and plenums for start- +35hp as a result
Seafoam noobs should repeat vac and gas in a month to get residual crud
Oil method of driving 30 minutes should include a few trips to vtec so oil flows thru the sensors and operators, vtec operates on oil pressure/pressure changers with rpm!
the vtec sliders get gummed up and wont operate,,,a problem discovered on gen3 and applies to us (afaik) so I do the extra cleaning to be safe
No need to turn off vsa or go from a stop- be rolling at 3500 rpm in 2nd gear and floor it, somewhere between 3700 and 4500 depending on year- it will go into vtec and a large increase in intake air sound is heard and a pushing feel into the seat, now go back down to 3500 and repeat until you know where yours comes on 4200 4300 etc
If it doesnt work at all, there is an electrical connector that gets seperated at trans change and has been forgotten to be reattached,,,,, ~on more than one car~
If still not sure- attend a ziner Meets in your area and have someone ride with you
makes sense....i had a tsx loaner while my car was getting a new trans, and above a certain rpm point it would really pull, even on part throttle...was hoping to get the same thing on my baby...maybe i'll put in the k&n filter and see if that helps
wait- you just got a new trans?
the connector wire for vtec may not be plugged together- no kidding
