How does the recall "oil jet kit" improves tranny life?
Ackniculous One
It will redirect trans fluid oil to the 2nd gear I believe where it's lacking oil distribution. My tranny seems to run better since I took it in to get the recall work done. 30K miles on the tranny, no issues...yet (fingers crossed)
6G TLX-S
It doesn't. All it does is to patch up the design defect of inadequet oil lubrication for the 2nd gear.
I love cars!
Originally Posted by fast-tl
...which prolongs the life of the tranny.
How many have gone bad after the oil jet fix, for a different reason?
Originally Posted by Bobbydoedoe
more like it prolongs the life of the tranny till 100K
I love cars!
I'm looking to trade my 96,000 '00 in Feb for a new '05 TL or a slightly used '04. Hopefully I won't be at 100K by then. I'm honestly wondering if the value of the 2G TL is going to tank once the odometer reads 100,000 since both my AcuraCare (which finally paid for itself!!!!) and the tranny extension run out at 100K. I'm worried the trade value will be absolutely horrible, but I don't have the cash to dump my oil-jetted tranny before early next year.
I think it is the same philosophy MicroSoft uses... in other words, it is just like the service packs, except MicroSoft releases these on a timely basis.
so the oil injector will temporarily help your transmission, but will still fail on you later?
thats sucks!
i guess they can't afford to give us all a new, revised, problem-free tramission and so we just get a small, cheap ass patch up job that will only extend the lifetime of our short-life transmissions.
thats sucks!
the tranny, well it would never make it that far unless you are extremly lucky!
6G TLX-S
thats sucks!
thats sucks!
mine died on the way to get it
The main issue with the tranny is with the 3rd gear clutch pack, not the 2nd.
All this really does fix is Hondas "rep" for fixing problems. Now imagine all the people who dont know any better, and think Honda is fixing the real issue for them.
Plus it probably helps get the trannies to 100K miles, so Honda can disavow all knowledge of any issue (cant wait, can you imagine all TSBs and complaints being pulled from All Data after Honda can somehow verify the "affected" trannies are out of warranty? I wouldnt put it by them)
Its not even a band-aid. More like a placebo.
-Chris
-Chris
-Chris
-Chris
Originally Posted by fsttyms1
there were 2 issues. 1 was more severe and was on its way to lawsuits. that is what the oil jet fix is for. teh 2nd problem which is what teh majority of us have is like you said the 3rd gear clutch pack (i know i had 3 trannies die on me now and i did alot of research into the issues) there is no known update for the failing 3rd gear issue. so any one who rebuilds the trannies sticks the same spec parts and the factory does
the only sign i ever had with all 3 trannies were a slipping clutch type shift between 2nd to 3rd.
i'm on my second trans.
i have about 90k on the car.
it shifts good now...but i just don't trust it.
whenever i drive the car...i'm just waiting for trouble signs to start again.
so.
if it happens again....and they don't cover me...
i'll look into a 3rd party rebuild.
think a rebuild from a non Honda shop would use better parts?.
or rebuild it differently?.
so.
so.
so.
Originally Posted by Da_iLLeZt_TL973
i think ACURA owes us ALLLLL new cars by now after all the shit they put us through anybody wit me on dat??????
Shouldn't cost them THAT much to give us all a free new car, right? Since according to them the problem only affected very few people
![Ecstatic](https://acurazine.com/forums/images/smilies/ecstatic.gif)
I mean, they could just arrange so that Oprah would invite us all to her show and give each one of us a present, but this time not a Pontiac G6 but rather a new TL.
![Racing](https://acurazine.com/forums/images/smilies/racing.gif)
But then I would be stuck with an Acura again... can't wait for this lease to end.
the oil jet is to prevent the 2nd gear shaft from over heating and breaking causing the wheels to lock up and cause a loss of control of the car.
I thought I was in the clear but nooooooo
![Damn](https://acurazine.com/forums/images/smilies/damn.gif)
Curious that it is dated Summer 2004 as I would NOT consider November 6th as a Summer 2004 Recall
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
9th Gear
There are TWO separate problems with the 2nd gen Acura transmissions:
1) Frequent failures by sudden downshifts, failure to upshift, jumping gears and slipping. The failure is the original reason for the 100K warranty and the replacement of failed transmissions with rebuilt units. To my knowledge there is not a 'new transmission' replacement for these units. Here is the NHTSA 'whitewash'. Only 35 complaints when 'closed'. Please complain at: http://www-odi.nhtsa.dot.gov/ivoq/
Make : ACURA; Model : 3.2TL;
NHTSA Action Number : PE02081
Date Investigation Opened: October 28, 2002
Date Investigation Closed: March 5, 2003
http://152.122.48.12/prepos/files/A...02081-15340.pdf
http://152.122.48.12/prepos/files/A...-PE02081-NN.PDF
2) The recall. This is for the inspection of the gear and oil jet addition to cool the second gear gear. This has caused (at last report) only two failures and has no relation to problem number 1
mugen_kid
11-13-2015 10:38 PM
