How do you know if your Catylitic (sp) converter is bad?
Old Nov 28, 2002 | 05:51 PM
Black TL's Avatar
My friend was showing me how to change my oil and I was telling him that when my car is warmed up, I hear a puffing noise coming from the bottom of my car. Sometimes it is quite loud and other times, it is faint. He said that it was coming from my CAT Converter and he didn't know if it was normal. Does anyone else experience the same problem? Thanks in advance.
Rosh
Old Nov 28, 2002 | 06:03 PM
SilverUA5's Avatar
If it's making crackling noise like something is loose inside, then it's time to replace it.
Old Nov 28, 2002 | 08:25 PM
fsttyms1's Avatar
a lot of times when the cat goes bad your exhaust will start to smell kinda rotten, usually your car wont run good (i.e. pluged cat) or like SilverUA5 said it might sound like something is loose inside
Old Nov 28, 2002 | 09:19 PM
Mstyle's Avatar
hurry up and get that replaced... Acura's warranty is only till 80k...
Old Nov 28, 2002 | 09:23 PM
Edward'TLS's Avatar
6G TLX-S
Don't worry, you'll know. If the cat has lost its effectiveness, the dash "engine warning light" will come on, and you will fail those emission tests.
Old Nov 28, 2002 | 09:43 PM
Black TL's Avatar
I'll probably have the dealer check it out when I do my 60k service.
The answer they will probably give is:
"No problem found. Everything OK at this time"
Old Nov 29, 2002 | 02:24 AM
dopeTL's Avatar
does anybody have their tl's straight through with no cat??
Old Nov 29, 2002 | 10:59 AM
fsttyms1's Avatar
no but ive got both resonators off
Old Nov 29, 2002 | 07:18 PM
JensH
Guest
Posts: n/a
One sure sign is the check engine lite.If it illuminates and the codes produced by it indicate a catalyst with reduced efficiency then it is time to replace it.A rotten egg odor is not really an indication of a worn catalyst.All cars under hard acceleration can smell like this.If your vehicle smells continuously of rotten eggs under all drive modes you may have issues with an engine running rich .If your catalyst makes crackling noises after engine shutdown do not panic , it is not abnormal for the exhaust to make some noises during warmup or cooldown.It is simply a case of metal expanding and contracting .this in turn can make some surprisingly loud noises .If you however tap on your catalyst and is sounds like a rock is bouncing around inside then possibly the catalyst bed inside may have fractured requiring replacement.As far as running the car without catalysts,removal of a federally mandated piece of emissions control equipment is a federal offense.My brother nearly got nailed for it in his old Mustang.The car was equipped with 4 catalysts ,at 10.000 dollars per missing catalyst he quickly saw to it that the car was restored to spec.jens
Old Nov 29, 2002 | 08:35 PM
KaMLuNg's Avatar
damn that is so illegal here to have a straight through no cat.. and actually it is better to have a cat... even if its the high flow one... it will burn off ne excess gas that may get through...
eastcoastguy
Oct 29, 2015 03:00 PM
Timmy18
Oct 17, 2015 03:58 PM
hrothgar02
Sep 28, 2015 11:08 AM
hpfiend
Sep 27, 2015 06:59 AM
Dman00tl
2G TL Photograph Gallery
Sep 25, 2015 10:34 AM
