How do i know my brake pistons are bad?
So my steering wheel started to shake everytime i come to a complete stop. So i got the rotors resurfaced and changed brake pads. Now, i have this noise that Acura dealers would explain as if the brakes weren't correct size for car, so it would move up and down while braking. I took the car back to the place that fixed my brakes to make sure they were the correct pads. Which they were. Now, everytime I come to a stop, there's a thumping noise coming from the brakes. Everything is fine with the brakes, rotors are resurfaced correctly and brake pads are honda pads. Is there a possibility the brake caliper pistons are bad? Is this causing that thumping noise like the pistons are stuck? thanks
Someone's blowing smoke. Calipers don't cause "thumping noises". Loose brake pads, improperly installed shims, or improperly installed rotors cause these problems. I would insist on the shop that did your brake work correcting the problem.
good luck
good luck
the calipers making noise is just a guess of where the noise might be coming from. i keep
taking the tires off and can't see if there's any problems. what part are the "shims" ? today, i lifted the front end up and took the driver side tires out to see. placed the car into drive and let it roll. Passenger side just rolled freely, when the driver side had trouble spinning as if the brakes were pressed on. Any opinions?
good luck
Originally Posted by Blazin_TL
sounds like a siezed piston, but they dont normally make a thumping noise though.
If you have a siezed piston in the caliper, the brake pad wear would have been way different between inside and outside pads.
Shops are responsible for their work, take it back!
SidhuSaaB
05-30-2020 12:40 AM
lanechanger
10-13-2015 10:56 AM
spoiler900
10-10-2015 06:48 PM
