How can i change the front corner bulb
Look in your manual...it shows you how to do it step by step.
it's not very hard, takes 20-40 minutes depends on how fast or slow you are at doing it.
remember not to touch the bulb with direct skin contact - the oils will make the bulb shatter when it gets hot.
I would jack up the front end, remove the front wheel, then undo the plastic inner fender housing, the part towards the front only. This is held in place by plastic rivets, just work at popping them out. You will see the backside of the bulb & the wire up high in the fender from there.
