horrible gas milage after AEM CAI install
Hey guys,
I just installed a AEM CAI and it seems that my gas milage has down big time. I know its winter, but i live in vancouver so not very cold at all. I dont know what it works out in miles, but i use to get 11 or max 12 litres/100 km.. I am not getting 14 litres/100 km. Any ideas????
I also just did a oil change, transmission fluid change and had my intakes cleaned out. I love the new intake and the sound but i don't know if this is the effect of it.
Any ideas????
Any ideas????
Dr. TLS
Hmmm... this is a fairly common problem. To alleviate it, one must not floor the car on every opportunity. I know how nice a CAI can sound but don't get carried away. Usually, limiting the flooring and VTEC-ing solves this problem. Let us know how it turns out. BTW, I am the proud purchaser of a CAI for myself. I am awaiting arrival of my very own Comptech Icebox.
You should get better gas mileage because the intake makes it easier for the motor to make power.
Then again, you'll be using more gas if you drive spirited all the time.
Are you throwing any CELs?
I am not really flooring it too much.. Same driving as always.. I always drive pretty fast but thats no different before the AEM.
Whats CELs?
Whats CELs?
Yeah, my mileage has gone down. I'm driving as "conservatively" as possible to see if there's an improvement. While I haven't taken numbers to confirm this, I'm willing to bet I'm getting less than 20 mpg with my city driving. That's pretty lousy for this car.
Dr. TLS
I'd take 23, but I don't think it's there.
After the new year I'm going to keep a log for a month or so and see how the car does.
Before my TL-S I had a supercharged Xterra. That thing drank gas like it was going out of style. I feel I'm going to the pump just as much with my Acura.
the last 2 cars i had the milage didnt go down with the aem. and mine hasnt gone down on the tl with my modified intake. i think you might be stepping on it a little moer than usual now to hear the sound. you should notice a drop in milage durring the winter months due to the different formula in gases and if you use the defrost the air is on
What do you guys set your tire pressure to. I have pirellie z rated 225/40/18. i think the factory tires say something like 32 and i have mine at 36 psi or something.
Dragging knees in
My MPG hasn't changed much, less than 1 MPG decrease.
But think about it. CAI delivers more, cooler air. That is bound to change the air/fuel mixture ratio. It would run leaner, and the ECU would adjust and compensate by adding more fuel. And fuel mileage is bound to be affective by this.
i have the z rated set at that.. The factory tires which are v rated are meant to be at 32. i dont really know what the z rated ones are suppose to be set at.
It'll be on the tire itself.
TL-S driver
the stocks should be at 32psi but aftermarket Z-rated should be around 36-38psi. That is what I was told by my tire guy.
As for your MPG, I noticed a HUGE loss when I installed my intake and headers, but then after I while I realized why. I was so happy with the power increase that I was averaging 90mph and gunning it every chance I get. I've had the installs for about 6 months now and my MPG is now back to normal, around 25mpg city. You may not notice it but you might be driving a little more aggressively after the install.
Ya I think you might be right. I think gunning it now takes more gas than it did before. If I drive hard now i totally notice the gas difference versus before. I drove like a granny and I got about 11L/KM so back to normal.
thanks for the tips.
BoricuaTL
04-08-2016 01:08 PM
InFaMouSLink
10-27-2015 06:51 PM
Abe_Froman
09-16-2015 01:27 PM
