HID question?
Old Mar 26, 2010 | 10:44 PM
Vman159's Avatar
HID question?
hey sorry but i searched this and couldnt find this. So i was wondering are the hid;s suppose to be the color pink/purple, cause when i turn mine on for a second they really blue but than they turn pink
Old Mar 26, 2010 | 10:47 PM
Gfaze's Avatar
S E L L
:shakehead Pink is not normal. Sounds like the bulbs are on their way out. Do both of them do this or just one?
Old Mar 26, 2010 | 10:49 PM
Vman159's Avatar
both, i dont think the previous owner changed them. what do you think?
Old Mar 26, 2010 | 10:51 PM
ANC297's Avatar
Bonki' Ehrite!
They are supposed to start of bright blue, with a shade of purple and then after a few seconds they go to a bright, super white.
Old Mar 26, 2010 | 10:52 PM
Gfaze's Avatar
S E L L
A little odd they both started going at the same time but it is possible.
They're probably the original ones, just replace them with a new set. That should take care of it.
Old Mar 26, 2010 | 10:55 PM
Vman159's Avatar
would you stay stock or go to 6k?
Vman159's Avatar
well mine start with bright blue but end with a pink
Old Mar 26, 2010 | 10:59 PM
Gfaze's Avatar
S E L L
Personally I prefer stock but some people like more of a bluish tint, which is what 6000K will give you. The only downside is that you lose a little bit of overall light output. Not sure if it would be too drastic of a difference between OE 4300K and 6000K. There's also 5000K which would be a bit whiter and you wouldn't notice any loss of output. Try one of our vendors in the BlackMarket. Hidextra sells bulbs pretty cheap so you can experiment. Excelerate sells the Kaixen bulbs which are widely praised but more expensive.
Old Mar 26, 2010 | 11:09 PM
ANC297's Avatar
Bonki' Ehrite!
Nothing more than 5k IMO.
Old Mar 27, 2010 | 01:21 AM
01tl4tl's Avatar
pink on startup is the death warning from the bulb
the other one wont be far behind
Always replace bulbs in pairs so intensity and color are the same
stock color 4300 Kelvin
I suggest 5000k, slightly more blue and picks out road lines and signs better than 4300
Old Mar 27, 2010 | 01:24 AM
01tl4tl's Avatar
normal bulb life for stock is 2500 hours, kaixen says they get 3000
I use mine all the time and dont worry about it
Original bulbs are ready for replacement on most of us gen2
they lose brightness with age, and color shift.. as you have seen
New HID bulbs need about 50-100 hours burn-in time to get fully color stable and max effect
Drive with lights on all the time to get some age on them
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
