HID Fogs
Old 07-10-2002 | 09:56 PM
HID Fogs
I noticed that the factory fog bulbs are HB2; my question is... has any one ever installed 9005 bulbs in place of the HB2's? I have a 9005 HID set from my Denali when I traded it in... the bulb seems to fit but the collar on the HB2 seems to be wider... would this affect the seal between the housing and the bulb?
Regards.
Old 07-10-2002 | 10:16 PM
SilverUA5's Avatar
Re: HID Fogs
Regards.
I assume your talking about the '02 and up stock foglights. They are 9006 and 9005 is two totally different thing. 9005 is what your highbeam is using, you can use that for your highbeams if you like, but it won't fit in the foglight housing.
Old 07-10-2002 | 11:10 PM
randomwalk101's Avatar
They are different bulbs..won't plug in. You want to use the right bulb for the right light.
BTW, is this real HID or those blue colored halogen bulbs?
Old 07-11-2002 | 01:54 AM
Edub-TL's Avatar
Sticky Rice OwnZ joO
Are you sure they are HB2??
Cuz HB2 is sometimes called 9003 or H4..
the TLS fogs which are 9006 are also known as HB4..
Old 07-11-2002 | 02:18 AM
WiLz's Avatar
get the 9006 hid conversion...looks great
Old 07-11-2002 | 02:33 AM
rominl's Avatar
yup they look great, it's a must
Old 07-11-2002 | 03:57 AM
NsX Pilot's Avatar
its nothing a file cant fix.....i think you can file the tabs off and put em in there
Old 07-11-2002 | 11:37 AM
songoku's Avatar
BlingBling INSPIRE 32V
Yeah, if you have Type-S, your fog light bulbs are 9006 and 9005 will not fit in there.
Look at the pic below.
One on the right is 9006 and 9005 on the left. Can you notice YELLOW round tab is slightly bigger than 9005 RED round tab??
Also the tab on top is on different sides.
Old 07-11-2002 | 08:02 PM
NsX Pilot's Avatar
like i said ....nothing a file cant fix....i had 100 watt bulbs in the high n low beams when i had my legend.....i just filed the tabs off that didnt line up and you also have to shave the inside tabs where the plug goes into the socket......this is only what i did and it worked fine ....if you are planning on doin this with high wattage halogen bulbs you will need to get the heavy duty wire harness kit otherwise you will burn up your lamp sockets.
Old 07-11-2002 | 08:58 PM
I'm sorry I meant HB4.. my bad! It is a real HID kit.. not those BS bulbs! So basically the 9005 bulbs wont work... oh well..
Old 07-11-2002 | 10:31 PM
Mr Hyde's Avatar
Theres a little confusion going on in here. Edub is absolutely right.
That B makes a HUGE difference
H4's are NOT THE SAME as HB4's
9006 = HB4, they are the same thing; LOWBEAMS
9005 = HB3, they are the same thing; HIGHBEAMS
TL-S NUT, On the 2002 and up TL,s if you actually look at the bottom of your headlight lens it lists our bulb used; D2R(lowbeam HID), and HB3(highbeam). I think the HB3 and 4 is just the Japanese classification for our 9005 and 9006 bulbs respectively.
That HID kit you have is a 9006 low beam bulb and WILL plug into and work with your foglights. Makes sense as NO US car like a Denali would use a 9005 bulb for its lowbeams, it would use a 9006 or HB4.
Hopefully mine will be here tomorrow. I just got the Phillips 6000k kit so my fogs really match my headlights.
Old 07-12-2002 | 12:10 AM
Tatewaki's Avatar
Is there any HID kit for H3? If there are, then I might convert them to 6000k when I get my PIAA fogs.
Tatewaki
Old 07-12-2002 | 10:46 AM
Hey TL-S Nut, If you don't want that, sell it to me. I want to put that in another car. thx. Email me at randomwalk101@yahoo.com
Avenger411
10-11-2015 03:53 PM
mshipon
2G CL Problems & Fixes
09-28-2015 12:14 PM
rhdune16
09-28-2015 11:31 AM
h22lude
09-27-2015 06:22 PM
Quick Reply: HID Fogs
